- 18 Mar 2008
Fermi pr0n!!
The card didn't come with a backplateDid you remove the backplate of the graphics card? If so, why?
I bought the Zotac version, only the front two screw holes match up
Well it's been an absolute DISASTER trying to install the 480 waterblock. People on here were making it sound easy. I was nervous about the thermal pads, and they turned out to be a horrid job. Mostly because EK says that they supply more than enough thermal pads than are needed for the job, yet I ended up using all of them
Not only that, it said to use the 1.5mm pads on the mosfets, yet all the pads were the same bloody size! So I ended up using 1mm pads on the mosfets. The backplate won't install either because the screw holes don't even line up with the screw holes on the card!
Then the EK instructions are goddam awful, it says to remove the block to check the contact is perfect. **** that, I'm not taking it apart and putting it back on again!
Somehow, I feel as if I've just spent money on pc that will royally FAIL, and I'm going to be standing there looking like an *******
Oh crap. I havea 470 back plate![]()
The the EK instructions are goddam awful, it says to remove the block to check the contact is perfect. **** that, I'm not taking it apart and putting it back on again!
The stuff arrived on Friday, so I ordered on thursday
You're fine thenLike I said, it could be worse. Have you managed to get the waterblock fitted then? I miss read for a minute, and thought you were having problems with the waterblock screws.
That's a good point. I'll have to buy loads of new thermal pads though, as I'm not reusing the ones that will have lots their stickiness.
Ok thanks. I'm pretty annoyed this build will have to go on hold for a little while![]()
