- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Antec LanBoy Air Modular Gamers Case - Yellow/Black @ £149.99 inc VAT
Meet the LanBoy Air. Nearly every part on this case, even the motherboard and PSU mounts, is modular and customizable. Up to 15 exhaust fans create positive air pressure inside the case that blows dust and heat out through panel perforations. Up front, the LanBoy Air’s AirMounts™ HDD mounting system literally suspends drives in mid-air for unsurpassable vibration and noise resistance. Along with its two internal 2.5” SSD bays and a front-panel USB 3.0 port, the LanBoy Air is the last word in high-flexibility PC case design.
- Fully-modular chassis
- Open-frame mesh panel construction
- AirMounts™ HDD suspension mount system for up to 6 HDDs
- 6 x internal 3.5” HDDs
- 3 x external 5.25” HDDs
- 2 x internal bottom-mounted 2.5” SSD bay
- Advanced cooling system - up to 15 fans
- Standard Cooling: 2 x front variable-speed 120 mm blue LED fans with stepless control knobs, 1 x rear 120 mm TwoCool™ blue LED fan, 2 x side 120 mm TwoCool™ blue LED fans for graphics cards cooling
- Optional fans: 2 x 120 mm fan for CPU and memory cooling, 6 x 120 mm side drive bay fan and 2 x 120 mm top fan
- Water cooling support: Top water cooling radiator fitting and Rear water cooling grommets
- 8 expansion slots for triple graphics-card configurations
- Maximum graphics card size: 16” / 406 mm
- Front I/O ports: 1 x USB 3.0, 2 x USB 2.0 and Audio (AC’97 and HDA compatible) In and Out
- Motherboards: Mini-ITX, microATX, Standard ATX
- Power supply not included
- Dimensions: 546 mm (H) x 269 mm (W) x 536 mm (D)
Only £149.99 inc VAT.
ORDER NOW
ORDER NOW
