 - 10 Mar 2009
I would get this but does it take rechargeable 18650 batteries?
You can get rechargeable 18650sa 18650 is a non-rechargeable single lithium cell battery (3v) that's roughly the size of two CR123A's stacked on top of each other.
I'm probably missing a trick here...But what use is a strobe function on a torch?
Ya know...its a torch...you turn it on....you see
Mick
Why do you want strobe? It has to be the most irritating mode on a torch unless you want to **** people off.
.Maybe to gain someone's attention in an emergency situation?
You could just wave the torch around though, pretty much the same effect.
BTW
The Lenser M7 is 'rated' at 220 lumens and you won't get any better than that with a 4XAA light. Push it to 6xAA and you can get 400 lumens but no stupid strobe, sadly.
You will also be lucky to find a torch with a spot to flood beam lens. Lenser have patented that feature and pretty much have it locked down.
