- 15 Mar 2010
- Bucks
yeh i didnt realise until i checked the stats that thor overpowered mutas, wish id figured that out earlier as i was building vikings, bc's in response."Thor is here" as long as you hear that line often while playing zerg you're going to be fine.
I had a problem with the zerg when I moved to plat now I do lame but sure tactic.
FE and mass marines + mass thors and pump up those thors with upgrades, I usually move out with 2nd wpn and 2nd armor upgrade with around 8 thors and some marines for meat shield
Works every time as lame as it is
oh welll....
,I might get a promotion soon but I am not quite sure if I will be able to handle Platinum at the moment.
I think I need to start looking at some proper tactics and build orders all of a sudden!
