You may find some settings posted earlier in this thread. I'm sure you will notice variations depending upon people's visual preferences but here are my settings to get you started:Could some1 be so kind to post the best setting to set mine from out the box.
u could use hdmi which carrys sound if your gpu supports it or use a 3.5mm plug from your sound card to the monitor.hey ive got a question, how do you connect the sound on the monitor speakers to the PC? ordering one of these tonight![]()
Perhaps I am biased but I'm not sure that a silver stripe and a stand with a square base (instead of the Hanns G oval base) are sufficient to elevate the Iiyama above the Hanns G in the style charts.
Does style matter when, for an extra £5 the Hanns G gives you:
- hdmi connection
- a bigger screen (27.5")
- better contrast
- better brightness
Iiyama ProLite E2607WSD 26" Widescreen LCD Monitor
I actually found this monitor a lot more stylish than than the HANS.G, anyone agree
http://www.overclockers.co.uk/showproduct.php?prodid=MO-052-IY&groupid=17&catid=1120&subcat=
the Iiyama ProLite monitors are far better quality tbh.At 1" bigger it would be hardly noticeable. And we havent even compared the two so how do you know they have better contrast and brightness. All the same i am with you on the HDMI connection, that would make the extra 5 quid worth it.
How can I argue with someone who owns both monitors?the Iiyama ProLite monitors are far better quality tbh.
