- 24 Apr 2006
- SE England
I have a 4D maglite. I bought it for walking the dog, and I often go places that are very quiet and a bit dodgy. The dog and I could handle most things, but I like having a weighty weapon at the same time.
Shame it is absolutely rubbish as a torch. I bought one from the supermarket for a fiver and it is far better.
Thinking of spunking £30-£50 on a good torch, what's the recommendation?
If you want to hang on to your maglite and make it much brighter for a tenner have a look at this thread: http://www.candlepowerforums.com/vb/showthread.php?t=277748 - is a cheap drop in module which blasts out 100% flood flight. It is no good for lighting up things that are at a distance but anything below 50m it is great for the price paid, colour is blue-ish but not as bad as the photos and far far better than your current maglite lamp. Trouble with many of the new flashlights these days is they are quite small and not very weighty unless you put your budget up.
The stock Maglite range of lights are very poor in terms of light output, not sure what maglite are playing at they seem like they can't be bothered with LED technology. But they still are great for whacking someone over the head, even my 2D maglite is brutally hard + heavy.
Do either of these have the switch on the side rather than the end? Like P7 do you have to hold the button in on them for the turbo mode?
Side switches aren't very common on flashlights these days. There are a couple around but not many.
The Quark comes in two flavours the regular or tactical. The regular cycles through the modes but pressing the clickie and the tactical is 2 mode programmable.To reprogram the tactical takes around 25 seconds. The regular vs tactical debate comes up quite often. But for me I prefer tactical because the regular is only able to start in dimmest or max mode, there is no memory so once the light has been turned off for more than 2 seconds it will default into dimmest or max mode. Highly annoying IMO.
