I posted the specs of my newbuild here http://forums.overclockers.co.uk/showthread.php?t=18180508&highlight=freddie
I was hoping for a lot better from the Coolit ECO, but got some wierd readings, If I tightened the screws too much, I cot 0° C for the CPU temp, backing them off a half a touch and revooting got me -44°C !!!!, backing off another half a turn returned me to idle readings of 44-46°C, This was with two Akasa Apache fans in push-pull, and the upper 230mm fan removed to accomodate the Coolit Radiator. I pulled the Cool-it, as with any sort of load temps rapidly climbed to60°C ++. Right now I am running the stock Intel fan and getting idle temps of around 42-44°C.
My problem is that Here in Thailand ambient temps in my computer room are around 85-88° F, My case is under the desk with a large wall mounted cooling fan blowing towards it, but no real airflow upwards and to the rear due to the desk. With the HAF 932 in 'standard' mode, ie 230mm fan at front/side/top blowing in and 140mm fan at rear as exhaust I think I might just be sucking hot air back in at the top (which has about 6" clearance with the underside of the desk, maybe I should reverse the top 230mm fan and blow with that as well. Other than that, I will be ordering a Prolimatemps super mega air cooler, just to try to reduce the temps into the 30's, If it doesnt work I guess my only option is a higher spec water cooler, I imagine that no-one on this forum has to put up with such high ambient temps, and yes, I could stick an aircon in my computer room, but I dont really want to. So any suggestions as to best higher end watercooling, Swiftech/koolance ??
regards
regards
