It uninstalls all the old driver files, and then installs the new driver, even says so in the release notes.
Not that you need to do that anyways just install over the top.
Ahh i was going by the leaked driver , thanks
Clean install resets profiles , that's all it does
Ahh i was going by the leaked driver , thanks![]()
Having a border on each side implies the games aren't running at native resolution and nVidia scaling is turned off.
Originally Posted by scandalous View Post
Just a heads up, Fixed aspect ratio is broken with these. Had the same problem with the 260.52 beta.
I kept getting a purple screen with artifacts on these drivers and windows recovering from some kernel error with my 460 GTX, so I've had to revert back to the old 258.96s. Anyone else has this?
Yeah that used to kind of annoy me too when i used to use vista x64 and ati graphics cards.the 59hz bug got on my nerves.
I don't know what all you guys are on about, nVidia cards never have any problems, they just work.
