Before you start…You will need the following:
1 x Recordable CD
Downloaded version of the Firmware update program Getting started:
1.
You can updated your OCZ SSD as either the primary boot drive or as a secondary drive
2.
Download the firmware upgrade utility .ISO image file that corresponds to your SSD model to your drive.
3.
Use this .ISO image file to Burn and Create a recordable CDNOTE: This will create a bootable CD for you to boot off of.
4.
Reboot your PC and enter the CMOS Setup utility by pressing Del or F1
5.
Change the SATA mode to IDE
6.
Change the Boot Device Order to CDROM/DVDROM as your First Boot Device
7.
Press F10 to Save and Exit
8.
Leave the newly created bootable CD in the drive
9.
Turn off the PC Firmware Upgrade Procedure: NOTE: the current utility does not require any jumper setting on the drive
1.
Turn On The PC and boot from the bootable CD
2.
You will see a “Select drive to Update 1.6” screen
3.
Select the number corresponding to the drive you want to update
4.
The utility will then prompt you: “Do you want to find Target Drives?”
5.
Press “Y” to get a listing of all the SSDs attached to the system
6.
Select the desired number of the drive you want to upgrade. In most cases it will be “1”
7.
This launches the utility which will complete in 1-5 seconds.
8.
Repeat the procedure in case multiple drives are upgraded.
9.
Turn off the PC. Verification:
1.
Enter the CMOS enter the CMOS Setup utility by pressing Del or F1
2.
Change the SATA mode back to the original mode(as it was set before. If the system was originally running in IDE mode, then no change is necessary)
3.
In Windows, Click START / Right click My Computer / Click Manage / Click Device Manager/ Double-Click Disk Drive / Right Click VERTEX and Click on Properties
4.
Select the “Details” tab and click “Device Instance ID” (WinXP) or“Hardware ID” Windows Vista /Windows 7 to verify the firmware revision number.
