Modern Volvos are not as solid as "Proper" Volvos
These units are more trouble than they're worth.
...but they're safer in a accident due to their crumple zones and all the safety measures that Volvo have engineered into the car
The Volvo and VAG diesel engines are fine
You certainly don't hear about turbos exploding on them like you do on a lot of common rail diesels. Injectors were a problem on earlier D5 units but this was sorted and is now quite rare.
I know this is OT, but the dealers have been telling me that they're having lots of problems with the new 1.6D, and I know that when the 2.0D was released there were quite a few issues.The Volvo and VAG diesel engines are fine![]()
why does the guy need a quick sale, for a smaller car, thats going to cost just as much or more to run, has his driveway shrunk?
The 1.6D engine is reliable, but only to a point. It is the same Ford / PSA engine that is used in the Focus / S40 / V50 / Cooper D and some Renaults / Citreons / Peugeots.
It has a huge design flaw, which causes oil to carbonise and block the pipes for the turbo. Ford had to issue a TSB, and redesign the oil feed and return pipes, benjo bolts etc to try and rectify this issue, but it remains to be seen if it actually does work as a long term fix. a lot of people have had turbo failures because of this. Some people have even had repeat turbo failures as the repair hadnt been done according to the ford TSB.
If your going down the diesel route i'd go for the 1.8 or the D5.
