Man of Honour
- 21 Nov 2004
An intermittent fault is the worst.
If you've tried it in another pc and the same thing is happening then it's probably a faulty card.
RMA time?
Could be a dying psu, have you tried a different psu?
Sounds like a fault then. Tried the oven baking method? Monitored the temps of the card before the crash? Does it only happen with L4D2? All other drivers updated?
You want him to put £400 in the oven? .
Just RMA it and state the fualt and you have tested it on two systems.
It isn't worth £400 if it is faulty and a fault that doesn't show up on RMA tests![]()
rma it i got a 5870 back for my 4870 x2
