Cheapo netbook - Medion Akoya. Anyone had one?
18 Jan 2007
Dorset
Evening all,
I've been looking a netbook recently, purely to browse the net, check emails and had settled on either a Dell 1012, or an ASUS 1001HA, when I stumbled across this possible gem, the MEDION AKOYA E1210, for £129, all in.
Has anyone had any experience with one at all?
Specs seem decent enough, with just the battery letting it down:
Technical details
* CPU: Intel® Atom™ processor N270
Operating system: Genuine Windows® XP Home 32-bit (OEM Version)
* Clock Frequency: 1.6 Ghz
* Memory Type: DDR2 667 MHz
* Memory size: 1 GB
* Hard disk capacity: 80 GB
* Screen size: 25,9 cm (10,2")
* Aspect Ratio: 16:9
* Resolution: 1024x600 pixels
* LED Backlight: No
Intel® Graphics Media Accelerator 950 based on PCI-Express technology
High Definition Audio sound card
* Integrated loudspeakers
Integrated webcam and microphone
* Multi-format memory card reader - SD, MMC, MS
Connections
3x USB 2.0
* 1x LAN (RJ45)
* 1x VGA
* 1x Microphone
* 1x Line Out
Fast Ethernet LAN port (10/100Mbit/s)
Wireless LAN 801.11b/g Draft-N up to 300 mbit/s* and 802.11b/g compatibility
*Only in the presence of a WLAN access point. To enjoy full performance you will need an IEEE 802.11n Draft Router, not included, 300 Mbit/s, is a gross value, reaches a max of 75 Mbit/s. at user level
Software (OEM Versions)
In the box
MEDION® AKOYA® E1210
* External AC adapter
* Li-Ion batter
Other information
* Dimensions: approx. 260 x 180 x 19/31.5 mm (WxDxH)
* Weight: approx. 1.2 kg incl. battery
* Warranty: 12 months
Usually I would say Medion laptops are rubbish, but at that price you cant really go wrong, even if you get a year out of it, it would still be a good deal, specs seem good
Got a DELL 1012 in the end! 250gig HDD, HD screen upgrade (higher res), WIN 7, 6 cell battery, all for £177 all in from DELL direct:D
My girlfriend has a medion laptop (not the one you're looking at). The build quality is far from perfect, but I don't think it's significantly worse than most brands out there. I'm pretty sure its someone else's model rebadged though.
Google thinks the akoya e1210 is an msi wind with msi scribbled out: Link in which case that's a good buy indeed.
I believe it is in fact a MSI Wind U100, same as an Advent version. Think I'll be happier with my DELL though, as and when it gets dispatched.
Got my new netbook yesterday (the PoV one), and wow! It's an amazing bit of kit. Does everything I wanted it to do, with the bonus of playing games. Had a go at Half Life, Dawn of War, and Peggle so far (dug out my old Steam account).
The trackpad is excellent, being built into the body of the chassis, keyboard is nice and responsive, screen is amazingly bright (even at just 60%), it had 2 gig of ram installed too! Best £130 I've spent in ages:D
