Nice, I was hoping that it was going to be regulated as opposed to a resistor which is what some LED lights use - resistor = waste of light!Forgot to add it is also regulated so over those near 2 hours the light is constantly BRIGHT! I misread that you currently use the original mag bulb in your mag, christ there is no comparison! - I think this drop-in will make you smile.
 Plus having a runtime of more than 1 hr is rather handy too.
Fenix TK30
From pics you posted, the Fenix TK30 gets my vote.
How much do these things cost?
you turned jonny 5 into a bike![]()
What is your favourite in your collection Deluxe1?
Why do Fenix do SO many different models?! It's so hard to pick one!
I thought I'd get to log on and willy-wave a bit with the Olight SR90 - but then along comes the man with the searchlight!
Arif
My Fusion 36 LED module arrived today but it doesn't seem to work.Forgot to add it is also regulated so over those near 2 hours the light is constantly BRIGHT! I misread that you currently use the original mag bulb in your mag, christ there is no comparison! - I think this drop-in will make you smile.
 I'm a bit of a Luddite, but have always wondered how anyone can buy anything from Ebay or Dealextreme or the like, & not expect the default result to be the receipt of a lemon - a good outcome will be out of the expected norm.  Whereas with a decent/specialist e-retailer - it should be the other way around, & customer service is more likely to be top-notch if things are amiss.  Good luck, though dude.My Fusion 36 LED module arrived today but it doesn't seem to work.
Tried it in a 3 cell mag and fresh D cell alkalines and nothing, tried it in a 6 cell and it lights up but isn't bright at all, in fact my 1 x 5mm LED keychain torch is brighter!
I've contacted the e-bay seller but have not heard anything back yet... Hopefully he'll send a replacement!![]()
