- 30 Sep 2005
postmans been and no game
I'm doing a naughty tonight
can someone give me a details on how to activate on steam early ? please
Guys, the games unplayable.
You do a lap then it starts stuttering quite badly and just gets worsed the longer you carry on.
This is with HD5870 and CAT 10.9a, looks like ATI screwed up again.
What is a "Flying Lap"?
Ahh I seeUsually to set a qualifying lap you need to do at least three laps.
An out lap (leaving the pits), a flying lap (timed from start line to start line) or multiple flying laps, and an in lap (returning to the pits).
If you select to do a flying lap, you get warped to the start of the straight to skip the out lap, ready to set a time on your next lap.
Thanks!Turning V-Sync off is supposed to help greatly. Also, changing the sound option from rapture to software eliminates a lot problems, Its also supposed to help with the gear changing bug as well
If your using 6 Cores you will need run msconfig and change it to use 4 cores only. The game doesn't detect 6 and will only use one and you get the problem you described. -Taken from Codemasters forum, but I cant find the link now. I think it might of been mentioned earlier in the thread as well
I'm playing on a 4870 at 1920x1200 settings at high and have none of the problems you describe.
Just tried it on Medium and Hard, lol. Nothing quite like winning in a Lotus. Think I will be sticking to the challege of Extreme![]()
Tried all three sound options and v-sync was disabled in CCC and game anyway and still it stutters with crossfire enabled or disabled..
Also, using i7 920 so that's not an issue or shouldn't be.
Thanks anyway, I guess I'll just play something else.![]()
Wish I had an American VPN to activate this![]()
