Man of Honour
- 21 Nov 2004
you could, but they're not rightworking it out yourself is more fun...
It is a good guide though. Didn't think to print screen the track
Hmmmm, really not getting into this so far. Why are the graphics so bland? Theres no colour or vibrancy at all! It all feels really flat. On top of that with my G25 you really can't feel when you're gonna lose the back end of the car in the rain. Ah well, I'll stick with it
Its been mentioned about punctures, but does anyone know if you can edit the game files to reduce/turn them off?
I am yet to complete a 40% race without getting one despite driving pretty easy on them.
It's just the way I play racing games, as I tend to go in a bit too hot always to then get the back end out and control it round the bend in order to make it (often sticking an inside wheel over the curb to help as well)
Do that in GRID, do that in Dirt2, do that in Forza on mates 360 .. can't do it here as I either spin out, or get called for cutting a corner
If there was ever a quote on how not to drive an F1 car, this is itIt's just the way I play racing games, as I tend to go in a bit too hot always to then get the back end out and control it round the bend in order to make it (often sticking an inside wheel over the curb to help as well)
You may not have the problems we are having, it seems to be totally random.My mate has given up on the PC version and went and got the PS3 version.
Now I can have it at £10..BUT I would have the same problems as him(only 60% GPU usage in races) as I got the same GTX.
And the list of bugs that are coming up at the CM site is just silly. I just can't make my mind up.
Make sure Rapture is not selected in the audio options, either choose software or if it is available hardware.There seems to be a rather noticeable input delay (no vsync), especially when shifting gears or taking chicanes.
Just a heads up for Hexicore users (Mainly AMD, not sure if it effects Intel) if you cant get to the race phase and it crashes when you pull out of the pits there is a fix available in this thread.
http://community.codemasters.com/fo...lp-1343/428639-game-crashes-prior-race-3.html
Was pulling my hair out (not that there is much left) trying to get it going and found that, worked for me on a 1090T, so hopefully will save you some hair loss, if you have the same problem as me.
Dave
