Componants don't work??
Though this motherboard provides 8-pin ATX 12V power connector,
it can still work if you adopt a traditional 4-pin ATX 12V power
supply. To use the 4-pin ATX power supply, please plug your
power supply along with Pin 1 and Pin 5
Along with Pin 1 and 5, what does that mean?
Also I talked to a 'technical' mate from work, and he said that the power supply is **** and I should get a more powerful one, what do you guys think?
The cpu power tends to be 4 or 8 pin. Your system will / should work fine with only 4 pin connected to the board.
Can you try with the board external to the case on the box the motherboard come in, just rule out shorting.
Any recommendation for a decent power supply, as I'm pretty sure that the PSU is the problem.
Also I plugged in my usb mouse when the computer was on, and the mouse was not light up as it normally is, does this mean the psu needs replacing?
well I think it the PSU or the motherboard but without testing it with another PSU its hard to tell normaly they beep if something is wrong so it could be the PSU but can't guarantee that
Problem with only one memory module you can't test if this is faulty, do you have the possibility of testing any parts in another machine.
Have tried running outside of the case like I mentioned above.
So I should take the mobo out of the case and try to run the system?
Also, if the motherboard was the problem, would there be any visual signs.
One more thing, if any of the parts were faulty do OCUK send a new one, or how does it work?
Thanks.
Yes, run the system external to the case, you will need to manually short the pine on the board or you may be able to position the case and use the start button.
You will need to contact Ocuk and get a RMA, best bet is to post in the customer forum below and link to this thread.
They will test your parts and replace if required with new parts.
http://forums.overclockers.co.uk/forumdisplay.php?f=116
Edit: Is it possible to take a picture of your setup and post here.
I can't get the set it up to turn on when its outside the case, as the wires dont go far enough. but here is the BIV
I though the problem was that the current PSU wasn't producing enough power; the one you've shown me is less power than my current one. Or have I misunderstood?
The psu with the case are not the most highest performing units and often don't get near the output, the Corsair is a excellent PSU and can pretty much maintain it output with out problem.
Your components probably only use 250-300W under load, the corsair will provide this 24/7 and more. If nothing else you have a known reliable PSU to test your setup.
andy.
