E5200 Overclocking and performance comparison.
18 Oct 2002
Aranyaprathet, Thailand
Installed the e5400 along with the CM hyper 212, not fully had a chance to play with it but got it sitting on 3.8ghz at the mo.
Will play with it over the weekend. Might see what I can pull out otherwise I'll be happy to stick with 3.8ghz or lower at a lower core voltage. Feels fast enough for my needs anyway.
What motherboard is that with??
24 Sep 2010
Thornaby a.k.a Middlesbro
great read :) enjoyed learning a hell of a lot of new stuff, i used to have a E2160 as my original stock cpu before my own build, i never imagined it could get too 3.6ghz! O.o i thought anything over 2.8-3 would make it explode lol
1 Sep 2009
London
Using a Gigabyte P35-DS3L, previous E2160 struggled to get past 2.9GHz on that! Now this E5400 has had no issues reaching 3.8GHz although still not had a chance to push it further but at the mo happy with performance.
Lol
nikzGfx
Nice overclock with a low vcore too! :cool:
Done any stress testing with it?
Nice deal! :D
So did it die from folding? or fan death?
Yup done Linx, Prime95 & Orthos. Prefer Linx for some reason as within minutes you'll know if there are any issues. Left Prime for 24 hours, tested Orthos overnight.
Man of Honour
OP
12 Jul 2005
Aberlour, NE Scotland
You have to remember that the E2160 is also coming from a lot further behind the E5400 as well, 1.8Ghz compared to the E5400's 2.7Ghz. 2.9Ghz is still a good clock for a E2160. If you look at it another way they have both reached overclocks of 1.1Ghz each.
Man of Honour
OP
12 Jul 2005
Very true, & aren't the E2xxx series on the 65nm process too?
Whereas the E5x00 are on 45nm, generally allowing for better clock speeds.
Yep. 65nm and a bit hotter running too. The E2140 i used in the tests needed 1.472v for 3.6Ghz. I am only using 1.32v for 4.13Ghz on my Q9550. I would add it to the test but don't have the same components anymore so it would be uncomparable to the rest.
26 Oct 2002
UK, Surrey, Guildford
1 last F@H question;), re running time, I meant total time, weeks/months/yrs?
Now I really want your Q9550! :D
......don't worry, I can't afford to atm anyway.
