Gaming pc spec
28 Sep 2010
Hey i was wondering if someone could put me the parts together for a gaming pc.
Budget 700 pound that doesnt include Case but add it anyways
Must run this games on ultra high.
Starcraft 2
WoW
css
cs1.6
Crysis
BF2
Mw2 - Black ops
HoN
Aion
Thanks.
hows this? depending on what you actually need.
Your basketProduct Name Qty Price Line Total
MSI GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 £229.11
(£194.99) £229.11
(£194.99)
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail £151.99
(£129.35) £151.99
(£129.35)
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard £109.99
(£93.61) £109.99
(£93.61)
Patriot Viper 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (PVS34G1600LLK) £70.49
(£59.99) £70.49
(£59.99)
OCZ ModXStream Pro 500w Silent SLI Certified Modular Power Supply £56.99
(£48.50) £56.99
(£48.50)
Silverstone SST-PS03B Precision Midi Tower Case - Black £42.99
(£36.59) £42.99
(£36.59)
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) £29.99
(£25.52) £29.99
(£25.52)
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366) £16.99
(£14.46) £16.99
(£14.46)
Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.99
(£13.61) £15.99
(£13.61)
Sub Total : £616.62
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 17.50% VAT : £109.96
Total : £738.33
remove the case, and bingo, £700.
Above build looks good but not 100% sure if RAM is compatible, P55 uses 1.65v where as AM3 uses 1.9v, thats rated at 1.7-1.9, if Stulid knows it works all good but if not you may want to dbl check
not a clue if it works, so try this corsair, which will still clear the third party cooler,
http://www.overclockers.co.uk/showproduct.php?prodid=MY-288-CS&groupid=701&catid=8&subcat=1517
to be perfectly honest, I should have just specced corsair ram in the first place! it just works!
Stulid's spec is great, but OP please note that you might still struggle in Crysis :). With my i5 OC'd to 4GHz and 5850 I have to turn off aa for acceptable fps if detail is maxed! Hopefully the 470 will give you the extra you need :). You could maybe consider making a few savings here and there, or perhaps going AMD to try and sqeeze a 5870 in, but personally I think that spec is well balanced and a winner. Nothing will ever run Crysis.
