I had the same thing. The one that got me was "what is the disadvantage of a CD as media", I shouldn't use quotes because it was that long ago, I can't remember the exact wording. The answer was "you can't write data to it". When I explained that, for a couple of thousand, you could get a CD-writer and that I had seen one in action, I was spoke to as though I was insane and a trouble maker. when I then went on to ask "well, how does the data get on to the CD in the first place?" I was again, a trouble maker
Also with SD 3.5" floppies. I was repeatedly told that 720k was the limit. When I tried to explain that that was only because of the PC file system limit. An Amiga could store about 880k on the same disk, I got the same response.
