Blonde hair shades.
It's really not as simple as buying a certain colour to bleach it. Depending on the colour of your hair (ie - the darker it is, the stronger the bleach) is what kind of bleach/developer you would buy. Search for your nearest sally's shop, and go ask them in there. This is what I do whenever I dye my hair. Although, you really won't be able to bleach it by yourself, it's very difficult, and if you aren't careful you will end up bald. :p
Well you learn something new everyday. Thanks for the lesson.
Thank you
Its bleached full blonde and his dark hair roots are growing in underneath.
You could say dirty blonde.
Bleaching your hair is also gay.
