Windows Server Expert Needed . . .
17 Jun 2006
we have just moved our phyical server to a VPS with FastHosts!
All works perfectly until Windows Server 2008R2 decides to automatically update itself periodically and I cannot for the life of me work out how to change the settings manually - they are all greyed out and unavailable even though I am logged in as as adminsitrator.
BEER TOKENS available to anyone who can either set up our machine the way I want it or who can explain to me how to successfully get into the auto-updates settings so that I can set them to manual please?!?!?
Khushy
07989 911911
[email protected]
If the options are greyed out the odds are they are been controlled buy group policy.
Start > Run > Gpedit.msc
Check the following are to see if anything is set;
Computer Configuration > Administrative Templates > Windows Components > Windows Update
That is your local policy
to see if anything is being set elsewhere by group policy
either do;
Start > Run > cmd
at the command prompt type gpresult and see if anything is applying to the computer side
or start > run > rsop.msc and see if the policy i mentioned in the first part is set or not.
Failing that it could be a change in the registry but hopefully that should get you sorted.
Yup, as above, the provider probably has a group policy set to point the server to a WSUS server for its updates, thus cutting down on windows updates bandwidth. You will need to open a ticket with FastHosts support and ask them.
PERFECT!
either do;
Start > Run > cmd
JOB DONE and many thanks - £5 beer token available - please send me a PayPal INVOICE and I will whizz it over to you!
Khush
[email protected]
I think it is against forums rules to offer monetary compensation. It is a help forum, we give our help freely! :)
It's not a case of what you want. Rules are rules after all. :)
I could be wrong of course. Just pretty sure it's not allowed.
It's a much friendlier GUI for seeing RSOP glad you like
I was kicking myself trying to remember that the other day. Just couldnt for the life of me find those 4 letters in my head!
Ended up doing a gpresult -h which creates quite a nice output but RSOP is still easier!
MMC then add snap in, easiest way if know something is there but can't remember
