OK, time for me to pick up a PSU for my new build. Criteria is that I'm looking for a top spec efficiency PSU for the long term. It also must be fully modular.
Expected Watt usage is around 450watts at load (see below), so my thinking is for top efficiency, very low noise levels at around 50%ish usage this equates to a minimum 750watt PSU, preferably a 850watt.
With that in mind, I'm thinking the Corsair AX850 is the way to go. £155 is also conveniently my budget limit for a PSU.
Expected Spec:
- i7 950 @ around 4.0Ghz+
- Rampage 3 Gene
- 6x2GB DDR3 (Geil Black Dragon)
- GPU - 5870 spec or above (looking at a single top end 6xxx series GPU when released)
- Sound Card
- 2 Optical Drives
- 2 SSDs
- 1 Hard Drive
- 6x LED Fans
Thoughts? Comments? Any other suggestions?
Expected Spec:
- Rampage 3 Gene
- Sound Card
- 2 Optical Drives
- 2 SSDs
- 1 Hard Drive
- 6x LED Fans
. . . what is it you guys know that I don't!
as im running sli gpu's i wanted a reputable unit with enough overheads for any future upgrades.
