Car covers
26 Apr 2003
West Midlands
Quick question, are there any car covers out there that aren't harmful to the paint, maybe having a microfiber underside?
They'd need a reason to come down here in the first place. The original perps won't come back down after being charged. The police think they saw the car in a picture from when the house was for sale.
Your lucky to get insurance with it parked on the street over night. A friend has a FQ360 and can only get isurance if its garaged over night.
I wouldn't put a car under cover outside - not only are you trapping moisture between the car and cover, but you are likely to damage the paint with the cover its self.
The car cover I linked to has a soft inner lining and a micro-perforated layer so will not trap moisture.
Unless you wash your car so it's perfectly clean before putting the cover on you're still likely to scratch it using any sort of cover that comes into contact with the car.
Ah I see what you mean? So u think it'll be the dirt on the car being disturbed by the cover causing the damage?
EDIT: Beaten
