Until they have a way to freeze the body without destroying just about every cell in it, it's pointless. They could never revive you anyway. I suppose it's possible they could salvage enough DNA to create a clone, but that's pointless too.
A better way of saying my post would be "Assuming the science boffs in the future could bring you back normal"![]()
No, and Tefal raises another important point. Unless you die within a few minutes of the freezer you're done for anyway. The body destroys itself very quickly after death. Imagine if they froze (and then thawed) you after rigor mortis had set in.
By the time they had the technology to unfreeze people its possible they would have the technology to reverse the damage done to your body or even implant our memories into a new cloned body.
, or they might just come back to you in time, like flashbacks, stuff which will trigger your memory.How did they like the cake? Worth the money?
Yup, exactly as I thought as well, could freeze us now, then when they have the technology, bring us back and inject us with something to repair any dead/ damaged cells and if you had cancer or any other illnesses, surely they would have a cure by then, so technically you would have a perfect, healthy body again![]()
No your cells are simply destroyed to "repair" them you couldn't use an inject you'd need to some how completely rebuild them remove all the unwanted chemicals fix all the broken proteins etc.
in other words it would be probably be easier to bring you back from a sample of your hair.
