- 11 Dec 2005
- Cheshire
The Logitech G35 headset. Game-changing immersion with 7.1 surround sound powered by Dolby technology for a detailed soundfield - hear your enemies before they see you. Featuring three swappable headband pads so you can choose the best fit, for long-lasting comfort; three customizable G keys for one-touch command over music, voice morphing, and more; on-ear audio controls for quick access to volume, microphone mute, and surround sound adjustments; and an adjustable, noise-canceling microphone that focuses on your voice and reduces background noise.
- 7.1 surround sound powered by Dolby technology delivers a detailed soundfield - hear your enemies before they see you.
- Three swappable headband pads let you choose the best fit, for long-lasting comfort.
- Three customizable G keys give you one-touch command over music, voice morphing, and more.
- On-ear audio controls provide quick access to volume, microphone mute, and surround sound adjustments.
- Adjustable, noise-canceling microphone focuses on your voice and reduces background noise.
Was £79.99 Inc. VAT
Only £75.19 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail @ £105.74 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.20GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £117.49 Inc. VAT
Only £105.74 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £123.36 inc VAT
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
Was £128.98 Inc. VAT
Only £123.36 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz (Socket AM3) - Retail @ £199.98 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Multiplier Unlocked
- Six Core Technology
- 3.20GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £224.99 Inc. VAT
Only £199.98 inc VAT.
ORDER NOW
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail @ £46.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.00Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was £51.69 Inc. VAT
Only £46.99 inc VAT.
ORDER NOW
AMD Athlon II X4 Quad Core 640 3.00GHz (Socket AM3) - Retail @ £76.36 inc VAT
At home or at play, AMD Athlon II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Quad Core Technology
- 3.00GHz Clock Speed
- AM3 Socket
- 2MB L2 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £87.98 Inc. VAT
Only £76.36 inc VAT.
ORDER NOW
Corsair Dominator GT 6GB (3x2GB) DDR3 16000C8 2000MHz Triple Channel Kit (CMT6GX3M3A2000C8) @ £176.24 inc VAT
The DOMINATOR-GT is the ultimate performance memory solution. Limited to only extremely high memory speeds, the Corsair DOMINATOR-GT only uses highly screened IC's to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology. With removable heat sinks, the DOMINATOR-GT modules can even be outfitted with additional upcoming accessories with enhanced features. Includes Airflow fan.
- Three matched 2GB modules for use in high performance Intel Core i7 Triple Channel systems
- Outrageously fast 2000MHz performance using 6GB of memory
- Ultra-low 8-9-8-24 latency
- Intel XMP (Extreme Memory Profile) Support
- Airflow Fan
- Density: 6GB (3x2GB Module)
- Speed: 2000MHz
- Timing: 8-9-8-24
- Pin Voltage: 1.65V
Was £199.98 Inc. VAT
Only £176.24 inc VAT.
ORDER NOW
Patriot Viper 6GB (3x2GB) DDR3 12800C8 1600MHz Low Latency Triple Channel (PVT36G1600LLK) @ £99.99 inc VAT
Patriot Extreme Performance (EP) Low Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 8-8-8-24 timings. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (8-8-8-24)
- 1.65V
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- Lifetime Warranty
- XMP Ready for Core i7 Processors
Was £109.99 Inc. VAT
Only £99.99 inc VAT.
ORDER NOW
Patriot Viper 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (PVS34G1600LLK) @ £70.49 inc VAT
Patriot Extreme Performance (EP) Low Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 7-7-7-20 timings and is available in 4GB kit capacity. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Low Latency (7-7-7-20)
- 100% Tested and Verified for AMD and Intel P35/X38 setups
- Lifetime Warranty
- RoHS Compliant
- XMP Ready
Was £74.99 Inc. VAT
Only £70.49 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3G1600LV4GK) @ £70.49 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1600MHz. Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops. OCZ DDR3 PC3-12800 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1600MHz DDR3
- CL 8-8-8-24
- Available in 4GB optimized kits
- Unbuffered
- Gold Layered Z3 XTC Heatspreader*
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Was £76.36 Inc. VAT
ORDER NOW
Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £70.49 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Was £74.99 Inc. VAT
ORDER NOW
MSI GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card with MAFIA 2 @ £340.74 inc VAT
Next generation gaming has arrived. Nvidia GeForce GTX 480 gives your games an adrenaline shot with the world's fastest performance and futuristic, visually stunning graphics. Experience heartpounding, cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jawdropping stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 480: pure adrenaline meets visual bliss.
- Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 1536MB GDDR5
- Memory Clock: 3696MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 480
- Shader Clock: 1401MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
- Supplied with Full Mafia 2 PC Game as of 27/08/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
Was £352.49 Inc. VAT
Only £340.74 inc VAT.
ORDER NOW
MSI GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 @ £223.24 inc VAT
Next-generation gaming has arrived. Nvidia GeForce GTX 470 gives your games an adrenaline shot with screaming fast performance and futuristic, visually stunning graphics. Experience heart pounding,
cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jaw dropping
stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 470: pure adrenaline meets visual bliss.
- Core Clock: 607MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3348MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 448
- Shader Clock: 1215MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £234.99 Inc. VAT
Only £223.24 inc VAT.
ORDER NOW
OcUK Value GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 @ £211.49 inc VAT
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Only £211.49 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card @ £169.19 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
The special inclined dual fan design effectively minimizes the flow of turbulence between two fans and enhances heat dissipation of hot area right underneath each fan. By unique design, WINDFORCETM 2X even enlarges air channel on the graphics card vents and creates a more effective air flow system in chassis. This special design helps heat dissipate quickly from GPU. In addition, WINDFORCETM 2X is equipped with 2 copper heat-pipes which strengthen the speed of heat dissipation.
Features
- Core Clock: 715Mhz
- Memory: 1024MB GDDR5
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1430MHz
- Display Connectors: 2x Dual-Link DVI-I & 1xHDMI & 1 X Analogue
- SLI Ready
- HDCP Capable
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £179.99 Inc. VAT
Only £169.19 inc VAT.
ORDER NOW
MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
The MSI N460GTX Hawk is the world's first graphics card to support voltage adjustment of the GPU, Memory and PLL making speeds, previously though of as impossible, easy to reach!
- Twin Frozr II Thermal Design 18 Degrees Celsuis Cooler and 8.1 dB Quieter!!
- Dual 8CM PWM Fans : Air flow from dual fans can cool down GPU/Memory/Power Module at once.
- Four heat pipes with SuperPipe Technology
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.
- 7+1 Phase PWM Design
- Higher current to GPU Powerv
- Higher overclocking capability
- Better stability in peak load
- Military Class Components
- Hi-C Cap provides more precise GPU voltage.
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.
- All Solid CAP for longer lifespan.
- APS (Active Phase Switching) & V-Check Points
- APS (Active Phase Switch) helps save power usage by controlling PWM automatically.
- V-Check Points allow users to read voltage directly by multi-meter.
- Core Speed:</b> 780MHz (Beyond 1000MHz possible but not guaranteed)
- Memory Speed: 1024MB GDDR5 3600MHz
- Shader Speed: 1560MHz (Upto 2000MHz possible but not guaranteed)
- Memory Type: GDDR5
- Memory Size(MB): 1024
- Memory Interface: 256 bits
- The world’s first graphics card supports voltage adjustment of GPU, Memory, and PLL.
- 7+1 Phase PWM design provides extra 30A current output power to GPU for better overclocking power capability.
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- Reduces power consumption by switching of power phases dynamically when not in use (active phase switching)
- Support Over Voltage function of GPU, PLL and Memory
- Support advanced fan speed control.
- Support burn-in stability test.
- Support PhysX technology effects for realist physics effect.
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience
Was £186.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM (Grade A Refurb - 3 Months Warranty) @ £39.94 inc VAT
Redefine your gaming reality with the OcUK GeForce® 8800 GTS 320MB PCI Express graphics card featuring the world's first DirectX® 10 GPU and a powerful unified architecture that delivers an incredibly true-to-life gaming experience. Power through games at record speeds and charge through game maps with vividly realistic, sun-up to sun-down HDR lighting effects while steering clear of mind-blowing physics effects such as explosions, fire, and smoke. And when you're not destroying the enemy, relax watching your favorite movies with NVIDIA PureVideo™ technology.
- GeForce 8800 GTS core running at 500MHz
- Shader Clock Speed of 1250MHz
- 320MB GDDR3 Memory running at 1600MHz
- 320-Bit Memory Interface
- 96 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 24 billion/sec
- Memory Bandwidth: 64GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
Note: These cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
!!<<img src="blue.gif">>!!
Was £46.99 Inc. VAT
Only £39.94 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card ***Supplied Assasins Creed Game*** @ £193.86 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 725MHz
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 128.0GB/s
- Processing Cores: 1440
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Supplied Asassins Creed Download Coupon PC Game (As of 11/08/2010)
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA terms and conditions (http://www.overclockers.co.uk/support.php)
Was £204.99 Inc. VAT
Only £193.86 inc VAT.
ORDER NOW
HIS ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card @ £105.74 inc VAT
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Year
Was £111.99 Inc. VAT
ORDER NOW
XFX ATI Radeon HD 5750 XXX 1024MB GDDR5 PCI-Express Graphics Card ***OcUK Exclusive*** @ £91.64 inc VAT
A single-slot card variant of the 5700 performance card family, it sports a uniquely designed fansink, with thermal capability of the HD 5750 dual slot channel fansink. This, combined with the open space provided by the single slot environment, ensures maximum airflow to the GPU.
An acoustic comparison of the 5700 family found that the XFX ATI Radeon HD 5750 single slot was much lower than the HD 5750 dual slot full cover fansink. Enhanced cooling and reduced noise is helped by fan speed. For gamers who have been waiting for the ideal single-slot graphics card, the XFX ATI Radeon HD 5750 has been worth the wait. The unique cooling capacity—and reduced noise levels—of this single-slot solution makes this a very attractive graphics card indeed. To optimize your gaming experience further, the overclocked XXX variant is also available.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Core Clock: 740MHz
- Processing Cores: 720
- Display Connectors: 2 Dual-Link DVI-I, & 1 Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Single Slot
- Supplied with Call of Duty Modern Warfare 2 Free Download Voucher
Was £94.99 Inc. VAT
Only £91.64 inc VAT.
ORDER NOW
Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) @ £110.44 inc VAT
The new 2.5" Crucial RealSSD C300 drive offers mobile and desktop users scorching-fast read speeds of up to 355MB/s. And because it has no moving parts, you will also enjoy a quieter, cooler, and more durable storage solution. Designed with high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management and the new SATA 6Gb/s interface, these drives dramatically improve data transfers for bandwidth-demanding applications like audio and video. The improvement in boot time and application load times push performance to new levels at the desktop too. You will experience improvement across a variety of common tasks such as viewing and editing photos, video, music and other media, gaming, communications, productivity and security.
- Capacity: 64GB
- Cache: 128MB
- Controller: Marvell 88SS9174
- Read: Up to 355MB/sec
- Write: Up to 70MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA 6Gbps
- Low Power Consumption
- Shock Resistant
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £114.99 Inc. VAT
Only £110.44 inc VAT.
ORDER NOW
Crucial RealSSD C300 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC128MAG-1G1) @ £234.99 inc VAT
- Capacity: 128GB
- Cache: 128MB
- Write: Up to 140MB/sec
- Shock Resistant
- Warranty: 3 Years
Was £239.99 Inc. VAT
Only £234.99 inc VAT.
ORDER NOW
Crucial RealSSD C300 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC256MAG-1G1) @ £469.99 inc VAT
- Capacity: 256GB
- Cache: 128MB
- Write: Up to 215MB/sec
- Shock Resistant
- Warranty: 3 Years
Was £499.99 Inc. VAT
Only £469.99 inc VAT.
ORDER NOW
OCZ Vertex 2E Bigfoot 120GB 3.5" SATA-II Solid State Hard Drive @ £176.24 inc VAT
OCZ Vertex 2 SATA II 3.5” Solid State Drives deliver the same industry-leading performance as the 2.5” edition in a larger, lower cost per gigabyte form factor to easily integrate into desktop applications without the need to install additional hardware.
Designed to excel in both sequential and random read/write speeds up to 50,000 4KB random write IOPS, the 3.5” Vertex 2 maximizes productivity when used as a primary storage or boot drive, minimizing program load times and completing tasks with blazing speed. Using the latest controller technology, the 3.5” Vertex 2 provides a faster, more responsive PC experience complete with TRIM support to keep your drive operating at peak performance in Windows 7 systems. Built with SATA 3Gb/s, Vertex 2 3.5” drives easily integrate into today’s desktop platforms as the ultimate storage upgrade.
Features:-
- Max Read: up to 285MB/s
- Max Write: up to 275MB/s
- Sustained Write: up to 250MB/s
- Random Write 4KB (Aligned): 50,000 IOPS
- Available in 90GB to 480GB capacities
- Native TRIM support
- Max IOPS Firmware
- Seek Time: .1ms
- 3.5" Anodized Casing
- 146 (L) x 101.6 (W) x 25.40mm (H)
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -45°C ~ +85°C
- Low Power Consumption: 2W in operation,.5W in standby
- Shock Resistant up to 1500G
- RAID Support
- Compatible with Windows XP, Vista, 7, Mac OS X and Linux
- MTBF: 2 million hours
- Ideal for desktop systems (no need for converter brackets)
- 3-Year Warranty
ORDER NOW
OCZ Vertex 2E Bigfoot 240GB 3.5" SATA-II Solid State Hard Drive @ £352.49 inc VAT
Features:-
- Max IOPS Firmware
- Seek Time: .1ms
- RAID Support
- 3-Year Warranty
Was £369.98 Inc. VAT
Only £352.49 inc VAT.
ORDER NOW
Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive - Black (Retail) @ £49.98 inc VAT
Samsung’s Optical Disc Drives maximise your Blu-ray experience. Not only do they maximise Blu-ray resolution, their 2-lens and 2-laser diode system reads and writes CDs and DVDs with more precision focus than most ODDs single lens system. Combine that with improved BD disc reading quality and DVD double layer disc writing quality, and you’ll find their Optical Disc Drives were built to be as reliable as they are enjoyable.
- SATA Interface
- Includes Cyberlink PowerDVD
Write Speeds
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 12x
- BD-R: 8x
- BD-RE: 8x
- BD-RE DL: 6x
- DVD: 16x
- CD: 48x
Was £53.99 Inc. VAT
Only £49.98 inc VAT.
ORDER NOW
Storage Options 6x Slimline Blu-Ray Writer @ £149.99 inc VAT
Storage Options presents this slim external Blu-ray writer drive which features support for all CD, DVD and Blu-ray formats, including BD-RE and BD-RE Dual Layer. Powered by Panasonic optical drive, this Blu-ray writer is capable of burning CDs at up to 24x, DVDs up to 8x and Blu-rays up to 6x. With support for ReWriteable (RE) and dual layer (DL) Blu-ray formats, this drive provides versatile recording options for all situations.
- Portable, slim and lightweight design ideal for travelling, business and students
- USB powered – no need for power adapters and cables
- Power saving function
- Fast USB connection – ideal for laptops, notebooks or netbooks
- SuperWrite technology supports all CD, DVD formats, including DVD-RAM
- Includes free CDBurnerXP software for simple burning of CDs and DVDs
Was £162.98 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Belkin 300Mbps N+ Wireless ADSL2+ Modem/Router with Storage Port (F5D8635UK4A) @ £44.64 inc VAT
Belkin's N+ Wireless Modem Router is based on the draft 802.11n 2.0 technology which provides a wireless network that has the range to easily cover any-size home or office. The N+ Modem Router has the bandwidth and speed for handling media intensive applications that take up large amounts of your bandwidth.
A USB Storage port on the back of the router enables you to connect USB storage devices such as an external hard drive or thumb drive to the network, saving you having to connect directly to individual computers on the network, this can reduce the electricity you use, thus saving you money. Now you can centrally store and share media content and files from the USB hard drive to every computer on the network.
The N+ Wireless Modem Router is the central connection point of your wireless network. You can add up to 16 computers to your Wireless Network with additional desktop and notebook adapters. Position your Belkin Modem Router in between your Broadband ADSL line and your computer to start sharing your broadband Internet access.
- USB Storage Port for easily connecting USB storage devices to your network
- 4 Ethernet Ports for Wired Connections
- ECO Features, Automatic Wireless Disable and Dim LED Features.
- Draft 802.11n 2.0 increases your networks wireless range and speed than 802.11g
- Download Speedometer bar that measures the download speed of your broadband
- Compatible with ADSL, ADSL 2 & ADSL 2+
- Push Button Security (Wi-Fi Protected Security)
- Easy setup Assistant and troubleshooting with Network Status Display to help you diagnose any network issues that may arise
- Free 24/7 technical support (local rates apply)
Was £45.81 Inc. VAT
Only £44.64 inc VAT.
ORDER NOW
Netgear DGN2200 ADSL2+ Wireless-N Modem Router @ £66.96 inc VAT
The NETGEAR N300 Wireless ADSL2+ Modem Router Router is ideal for both professional and personal Internet use, providing Wireless-N speed for simultaneous downloads, voice and music, and online gaming. Complete with a built-in DSL modem, it is compatible with all major DSL Internet service providers. Storage for downloads is easy with ReadySHARE™ for shared access to a USB storage device.
-Built-in DSL modem — ADSL2+ modem and router combined create complete gateway for DSL Internet connection
-Faster downloads and online gaming — Provides Wireless-N speed for simultaneous downloads, streaming voice and music and online gaming, in addition to basic Internet applications
-Share Internet connection — Allows Internet broadband sharing and the freedom of wireless Internet usage
-Shared storage — ReadySHARE™ provides fast and easy shared access to an external USB storage device
-Easy setup — Smart Wizard® CD with graphical installation guide and multi-language support
-Live Parental Controls — Keeps your Internet experience safe
-Blocks unsafe Internet content and applications and can be managed from anywhere
Protects connected devices through the router such as PCs, gaming consoles, and iPod touch®
To learn more visit www.netgear.com/lpc
-Jitter-free voice and gaming — Automatic Quality of Service (QoS) for reliable Internet connections
-Guest network access — Provides separate security and access restrictions for guests using the network
-Secured connection — Push ‘N’ Connect offers a secured wireless Internet connection at the push of a button
-Compatibility — Compatible with all major DSL Internet service providers (ISPs)
!!24-Hour Phone Support!! - NETGEAR's 24x7 support guarantees that if you ever have trouble with this or any product from NETGEAR there is always someone there to help you on the phone.
Was £68.98 Inc. VAT
Only £66.96 inc VAT.
ORDER NOW
Linksys by Cisco WAG160N-UK 300Mbps Wireless N ADSL2+ Modem/Router @ £66.96 inc VAT
nonl2br
The Linksys Wireless-N ADSL2+ Gateway is the all-in-one solution for Internet connectivity. The ADSL2+ Modem function gives you a blazing fast connection to the Internet, far faster than a dial-up, and without tying up your phone line. The Router function lets you share your high-speed Internet connection with all the PCs in the house.
<br />
<br />
- High-speed ADSL2+ Modem gives you a fast, "Always On" connection to the Internet<br />
- Connect your PCs via the built-in Router and 4-port Switch to jump start your Ethernet network and share the Internet throughout the building<br />
- Built-in Wireless-N (draft 802.11n) Access Point also lets you connect without running wires - far faster than standard Wireless-G<br />
- MIMO technology uses multiple radios to create a robust signal that travels much farther with reduced dead spots<br />
Was £68.98 Inc. VAT
ORDER NOW
Linksys WUSB100 300Mbps Wireless RangePlus USB Network Adapter @ £24.08 inc VAT
Connect with convenience, without wires in more locations. Plug the RangePlus Wireless Network USB Adapter into your computer and enjoy the freedom of fast, reliable connectivity - around the house or on the go.
- Conveniently compact adapter plugs into your laptop or desktop’s USB port
- Industrial-strength 128-bit encryption
- RangePlus smart antenna technology delivers reliable high-speed connectivity to wireless networks, with extended range and reduced dead spots
- You can access the Internet, printers, storage and other networked devices without having to plug in
- Offers optimal performance with Wireless-N networks, but works with Wireless-G and -B networks as well
Was £41.11 Inc. VAT
Only £24.08 inc VAT.
ORDER NOW
NetGear XAVB2001 Powerline AV200 Ethernet Adapter @ £77.80 inc VAT
- Extends a high-speed Internet connection to any power outlet
- Perfect for connecting HDTVs, Blu-ray™ players, DVRs, PCs, and game consoles to your home network and the Internet
- Compact design with push-button security
- Automatically powers down when not connected or not in use
- Disable LEDs to help save energy
- Packaging manufactured with at least 95% recycled materials
- Just plug into any electrical outlet
Was £85.00 Inc. VAT
Only £77.80 inc VAT.
ORDER NOW
Devolo 1540 dLAN 200 AVSmart+ Adapter with LCD Screen @ £55.21 inc VAT
- Quick: The devolo dLAN® 200 AVsmart+ offers a transfer rate of up to 200 Mbps to a cable length of 300 metres.
- Easy: True plug & play - the encryption button makes it possible to start up easily and securely. Without a computer, including encryption.
- Clearly arranged: The dLAN® screen display developed in-house by devolo shows the connection status with other powerline adapters.
- Convenient: The integrated socket ensures that no electrical outlet goes to waste. Furthermore, a special mains filter ensures best possible transmission.
- Efficient: Thanks to the intelligent Dynamic PowerSave technology, the dLAN® 200 AVsmart+ reduces its energy consumption automatically by over 60 percent.
With the dLAN® 200 AVsmart+, devolo supplies the best home network over the electrical wiring! Without any expertise, you can connect your network-compatible devices such as PC and Mac computers, game consoles, network printers or NAS hard drives to one another and to the Internet at a maximum speed of up to 200 Mbps. dLAN® does this wirelessly – over the entire household electrical wiring. This way, every power outlet becomes a network jack in no time! devolo's dLAN® adapters also combine easily and can be expanded again and again. An example: Have you bought a new IPTV set-top box (like T-Home) or a new laptop? Purchase another dLAN® adapter and your new network-compatible device is quickly and securely connected with the Internet and the other devices in your home LAN.
There are many good reasons for you to reach for devolo's dLAN® 200 AVsmart+: With the latest dLAN® generation, it not only offers maximum data transmission, its outstanding range also makes it possible to bridge cable lengths of 300 metres. This is confirmed by not only market leader devolo's German development, but also tests in numerous leading trade journals! The dLAN® screen status display developed in-house by devolo shows the connection status with other dLAN® adapters; the encryption button enables secure operation. But the dLAN® 200 AVsmart+ still has more to offer: The integrated socket ensures that no electrical outlet goes to waste. Furthermore, the integrated mains filter ensures best possible transmission. A clean environment was also in mind during the development. The dLAN® adapter consists largely of recyclable materials. But that's not all: Thanks to the patented power-saving technology Dynamic PowerSave, the dLAN® 200 AVsmart+ reduces its energy consumption automatically by over 60 percent.
Was £56.39 Inc. VAT
Only £55.21 inc VAT.
ORDER NOW
Belkin F5D8633UK4A 300Mbps Wireless N ADSL2+ Modem/Router @ £30.54 inc VAT
Connect your wired and wireless desktop computer and notebooks to your Belkin N Wireless Modem/Router to share your broadband internet access. Now you can quickly exchange documents, share resources, and distribute large video and music files throughout your network at a link rate of up to 300Mbps which can save you time.
Belkin's advanced security protects both your wireless and wired computers from hackers and intruders, providing you with the peace of mind you require for your security of your data and personal information. You can add up to 16 computers to your wireless network with additional notebook and desktop adapters.
- Data transfer rate of up to 300 Mbps
- Plug and Play Setup making it easy to setup your home network
- Ports: ADSL Phone Line - 10/100 LAN Port - 4
- Security Wi-Fi Security modes: WPA, WPA2-Personal, 64-bit/128-bit encryption and multiple SSID to ensure you're protected against viruses and hackers
- Backwards compatable with Wireless A/B/G/N receivers
- VPN Support: Allows you to access your network from any computer in the world.
Was £31.73 Inc. VAT
Only £30.54 inc VAT.
ORDER NOW
TP-Link Wireless N 300Mbps Wireless USB Adapter (TL-WN821N) @ £10.56 inc VAT
The TL-WN821N Wireless N USB Adapter complies with IEEE 802.11n, IEEE 802.11g, and IEEE 802.11b standards. Wireless transmission rates can reach up to 300Mbps. The adapter employs MIMO technology and has internal Intelligent Antennas providing even better wireless performance, transmission rates, stability and coverage. At the same time, CCA technology automatically avoids channel conflicts using its channel selection feature. This product supports 64/128-bit WEP encryptions, as well as WPA/WPA2 and WPA-PSK/WPA2-PSK encryptions and mechanisms in addition to the adapter’s QSS (Quick Secure Setup) feature, allowing users to quickly and easily setup wireless security. This product can also simultaneously operate bandwidth intensive applications such as voice, and video. Applications using a lot of bandwidth that are sensitive to interruptions such as voice and video applications are given priority in order to assure quality. It also works well with other 11g and 11n protocol wireless products.
- 300M Wireless transmission rate
- MIMO technology with stronger signal penetration strength, wider wireless coverage, providing better performance and stability
- CCA technology automatically avoids channel conflicts using its channel selection feature
- Compatible with 11g and 11b equipment, Intel Centrino Compatibility tested
- Supports Sony PSP for online game
Was £12.91 Inc. VAT
Only £10.56 inc VAT.
ORDER NOW
OcUK Value 150Mbps N Lite Mini-Size Wireless USB Network Adapter @ £7.63 inc VAT
This Wireless Local Area Network(WLAN) 802.11 b/g/n USB dongle, by inserting a PC USB socket and connecting a wireless access point through wireless interface, can provide the transmission of broadband data service, which are suitable for using in a wide range of both residential( at-home) and commercial (offices, apartments, hotels, warehouses) network applications. It gives you a blazing fast connection to the internet, far fast and more convenient. This USB dongle is a high-performance wireless access tool, and can support downstream data rate up to 150Mbps and upstream data rate up to 150Mbps.This device can enable a computer or device to support 802.11 b/g/n Wi-Fi. Within Wi-Fi network, a computer or device can be connected to your Internet Service Provider (ISP) . It fully support industry standard compliant security 802.11i , Dynammic Frequency Selection(DFS) and Transmit Power Control(TPC) 802.11h, Quality of Service (QoS) 802.11e.
Product Specifications
- Speed: Up to 150Mbps data transfer rates in 11n mode
- Standard: IEEE 802.11n, IEEE 802.11g, IEEE 802.11b
- Security: WEP 64/128, WPA/WPA2, WPS
- Certifications: IEEE 802.11 compliant, Wi-Fi 802.11n Draft 2.0 and 802.11b/g certified8
- Interface: USB 2.0
- Operating Channels 11 for North America, 13 for Europe, 14 for Japan
- Operating Frequency 2.4 GHz-2.5 GHz
- RF Output Power: 11b: 18+/-1.5dBm, 11g: 15+/-1.5dBm , 11n: 15+/-1.5dBm
- Operating Temperature: 0? ~ 45?
- Operating Humidity: 10 % ~ 90 % no freezing
- Storage Temperature: -20? ~ 70?
- Storage Humidity: 5 % ~ 90 % no freezing
- Supported OS: Windows 2000, XP, Vista (32/64 bit) Windows 7, Mac OS and Linux
Was £9.39 Inc. VAT
Only £7.63 inc VAT.
ORDER NOW
OcUK Value 300Mbps Wireless-N PCI Adapter @ £15.26 inc VAT
Are you craving for a faster, more reliable Wireless connection? Feed up with the lack of speed of your existing 802.11g Desktop PC or Server?
The NWP210 is a Wireless-N PCI Adapter providing a 300Mbps transmission rate. It adopters the latest 802.11n wireless networking standard and MIMO technology for a large coverage area with reduced dead spots. Whether you are surfing the net, using voice over IP, watching streamed video, playing online games, downloading, or just need a quick connection for a computer or notebook, the NWP210 makes an ideal wireless solution.
Product Specifications:-
- Standards::IEEE802.3, IEEE802.3u, IEEE802.3ab, IEEE802.3x, SNMP, IEEE802.11b, IEEE802.11g, IEEE802.11n
- Encryption mode:64/128bit WEP, WPA/WAP2 and WPA-PSK/WPA2-PSK
- Max. Wireless Speed: Up to 300Mbps
- Frequency: 2.4GHz ~ 2.5GHz
- Interface: one PCI connector
- Antenna: 2 fixed 2.2DBI antennas
Was £16.99 Inc. VAT
Only £15.26 inc VAT.
ORDER NOW
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) @ £80.99 inc VAT
Windows 7 Home Premium offers a rich, dynamic entertainment experience on your PC, making it easy to create a home network and share all of your favorite photos, videos, and music. You can even watch, pause, and rewind TV or record it to watch whenever and wherever you want.
- Record TV on your PC: Watch, pause, rewind, and record TV, movies, and other video content with Windows Media Center, updated to manage a single TV guide containing both standard and digital high definition TV shows.
- Personalise your desktop: Easily change backgrounds, window colours and sounds to reflect your personal style. You can even turn your desktop into a slide show of your favorite photos.
- Share files across the various PCs in your home: Use HomeGroup to connect your PCs running Windows 7 to a single printer. Specify exactly what you want to share from each PC with all the PCs in the HomeGroup.
- Pin any program to the taskbar: Any program is always just a click away - and you can rearrange the icons on the taskbar just by clicking and dragging.
- Stream music files on any network-connected device: Just open Windows Media Player, right-click on what you'd like to hear, select Play To, and you'll see a list of devices and PCs on which you can play your music.
- Find virtually anything on your PC - from documents to photos to e-mail: Just click on the Start button, and enter a word or few letters in the name or file you want into the search box, and you’ll get an organised list of results.
- Access recently used files with just two clicks: Right-click the relevant program icon (such as Word) on your taskbar and Jump List will show your most recent, frequently used, and pinned Word documents.
Was £82.99 Inc. VAT
Only £80.99 inc VAT.
ORDER NOW
SpeedLink Medusa NX 5.1 Gaming Surround Sound Headset (SL-8793-SBK) @ £44.64 inc VAT
Find yourself right at the centre of the action with this 5.1 surround headset: hear a door closing behind you to your left or listen to the footsteps of your opponent who’s in front of you. Plug the Medusa into the 5.1 soundcard on your PC or using the phono adapter and mains adapter, into your DVD player.
- Real 5.1 gaming surround sound
- Real all-rounder - can be used on all sound sources
- Brilliant voice transmission
- Highest level of comfort
- Adjust sound channels individually
- Collapsible headset including carry case
- 3.8m cable
Was £46.99 Inc. VAT
ORDER NOW
Noctua NH-D14 Dual Radiator CPU Cooler (Socket LGA1366/LGA1156/LGA775/AM2/AM2) @ £63.98 inc VAT
Combining a massive six heatpipe dual radiator design with an exquisite NF-P14/NF-P12 dual fan configuration, the NH-D14 is built for ultimate quiet cooling performance. Topped off with a tube of Noctua's award-winning NT-H1 thermal compound as well as the new SecuFirm2 multi-socket mounting system, the NH-D14 is an elite choice for the highest demands in premium quality quiet cooling.
- Six heatpipe dual radiator design
- Dual NF-P14/NF-P12 fan setup
- Asymmetrical design for high compatibility
- Excellent component cooling
- SecuFirm2 multi-socket mounting system
- Dimensions(with fans): 160 x 140 x 158mm ( H x W x D)
- Materials: Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
- Fans Included: Noctua NF-P14 / Noctua NF-P12
- Fan Speeds: 1200 & 1300 RPM
- Fan Aiflow: 64.9 & 54.3 CFM
- Fan Noise: 13.2 & 12.6bDA
- Six Year Warranty
Was £66.99 Inc. VAT
Only £63.98 inc VAT.
ORDER NOW
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) @ £32.98 inc VAT
Venom, this cooler is definitely rock and roll. Venom delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.
The Black cover and nickel plated heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Four high capacity 8mm heatpipes with direct CPU contact provide rapid heat transfer from CPU to 45 aluminium fins. Anti-vibration rubber fan mounting pins provide easy installation and help to elimate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.
The Smart cooler design allows for the installation of a second fan, giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.
- Dimensions: 120 (W) x 96 (D) x 160 (H) mm
- Fan speed: 600-1900 RPM (PWM controlled)
- Max airflow: 83.63 CFM
- Noise level: 6.9 - 28.9 dB(A)
- Performance 12cm PWM fan in killer Viper yellow
- 4 high capacity 8mm heatpipes with direct CPU contact
- Award winning S-FLOW fan blades provide 30% more airflow
- Smart design allows for a 2nd fan for extreme performance
- Rubber fan mounts for easy installation and quiet performance
Was £35.99 Inc. VAT
Only £32.98 inc VAT.
ORDER NOW
Cooler Master Hyper 212 Plus (Socket AM2/AM2+/AM3/775/1156/1366) @ £17.99 inc VAT
Succeeding the popular Hyper 212, the Hyper 212 Plus carries on the legacy of providing a great balance of performance and noise level during high and low speed operations.
Hyper 212 Plus is Cooler Master's first cooler to be equipped with an all-in-one mounting solution that includes LGA 1156 and 1366. Direct Contact heat-pipe is now also utilized in this latest update.
- Versatile all-in-one mounting solution for Intel Socket LGA775/1156/1366 and AMD Socket AM2/AM2+/AM3
- Silent operation with minimal noise level at 13 dBA.
- Excellent airflow design with compact heatsink dimension.
- Computer aided heatsink design provides fin optimization with perfect balance between high and low speed operation.
- 4 x Direct Contact heat-pipes for seamless contact between CPU surface and cooler.
- Wide-range PWM fan with unique blade design for excellent airflow.
- Upgradable to dual fans and swapping of fans with extra fan-clips included.
Was £19.99 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Lian Li NC-09B 17" Notebook Cooler Pad - Black @ £37.99 inc VAT
The typically high standard of workmanship you can expect from Lian Li has been put into this laptop cooler, thus giving you a high quality, and powerful cooling solution for your hot laptop.
- Huge 220mm 5V silent DC Fan with Blue LED
- Large steel mesh allows extra air-flow under the notebook
- Dual USB power connectors ( standard & mini ) with on/off switch.
- Three level height adjustment and Smooth base panel for user who want to use NC-09 on their laps.
- Desiged for 12.1”/14”/15”/17” High End notebook
- Dimensions: 400mm x 337mm x 34 mm (W,D,H)
Was £39.99 Inc. VAT
Only £37.99 inc VAT.
ORDER NOW
Asus X58 Sabertooth TUF Intel X58 (Socket 1366) DDR3 Motherboard @ £146.99 inc VAT
Covering all the Essentials of Reliability
The key emphasis for TUF Series motherboards lies in enabling prolonged use. The SABERTOOTH X58 can keep going round the clock with no pause thanks to its meticulous thermal design, which means heat and stress are not obstacles. This new thermal design revolves around CeraM!X Heatsink Coating Technology, using revolutionary ceramic application on vital motherboard surfaces and components to ensure unrivalled heat resistance and dissipation. Thus, it is the perfect choice for server functionality and extreme, steady reliability. CeraM!X application has never been done on a motherboard before the ASUS TUF Series entered service.
Reliability Tested to Military Grade
The SABERTOOTH X58 from ASUS uses heavy duty materials and parts to ensure truly unmatched capabilities in terms of stability, reliability, endurance, and value.
The chokes, solid state capacitors and MOSFETs have all been tested under the most arduous of conditions and harsh environments based on military standards, providing users with a proven heavy duty solution.
TUF Series motherboards are ruggedized from the ground up, so they can handle more than just long-haul usage and heat. They are also tested to server-grade standards and can stand up to humidity and ambient temperatures to an exponentially larger extent than normal motherboards. As a consequence, they are long-life products users can install with complete confidence.
Being strong does not mean TUF Series motherboards compromise added features. The SABERTOOTH X58 ships with new data transfer standards USB 3.0 and SATA 6GB/s, so it offers some of the latest innovations in addition to superior strength. It is a complete package of guaranteed reliability and compatibility.
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express
- Memory: 6x DDR3 DIMM 1866 /1800 / 1600 / 1333 / 1066 MHz (Max. 24GB) / Triple Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 2x PCIe 2.0 x16 Slots, 1 PCIe x4 Slot, 2x PCIe x1 Slots & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 6x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x SATA 6Gb/s
- LAN: Marvell 88E8056 Gigabit LAN
- Audio: ALC889 8-channel High Definition Audio CODEC
- 8x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- 1x S/PDIF Out (Optical)
- 1x S/PDIF Out (Coaxial)
- 8 Phase Power Design
- MemOK!
- T.U.F. Power engine design
- T.U.F. Components: Chokes, capacitors and MOSFETS certified to military standards
- E.S.P - Efficient Power Switching
- CeraM!X Heatsink coating technology
- Asus Fan Xpert
- Form Factor: ATX 12x9.6 inches
- Warranty: 5 Years
Was £156.99 Inc. VAT
Only £146.99 inc VAT.
ORDER NOW
Gigabyte GA-890FXA-UD5 AMD 890FX (Socket AM3) DDR3 Motherboard @ £129.99 inc VAT
The 890FXA-UD5 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the Gigabyte 333 onboard acceleration technologies. Featuring the world’s first USB 3.0 logo certified host controller from NEC Electronics, the AMD 800A series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via the AMD SB850 chipset, the Gigabyte AMD 800A series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6Gbps. Coupled with RAID 0 (Stripe) mode, SATA Revision 3.0 enables a data transfer boost of up to 4x the speed of SATA Revision 2.0. The AMD 800A series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
- CPU: AMD Phenom II/Athlon II/Sempron 100 Series Processors (Socket AM3)
- Chipset: AMD 890FX / SB850
- System Bus: Up to 5200 MT/s HyperTransport 3.0
- Memory: 4x DDR3 DIMM 1866(OC) / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Expasion slots: 4x PCIe 2.0 x16 Slots, 2x PCIe x1 Slot & 1x PCI Slots (Supports ATI CrossFireX Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 6x SATA 6Gb/s (RAID 0, 1, 5 and 10), 2x SATA 3Gb/s & 2x eSATA 3Gb/s
- LAN: Dual RTL8111D Gigabit LAN
- 14x USB 2.0
- 2x USB 3.0/2.0
- 3x IEEE 1394a
- 1x PS/2 COMBO (Keyboard & Mouse)
Was £139.99 Inc. VAT
Only £129.99 inc VAT.
ORDER NOW
MSI P55A-G55 Intel P55 (Socket 1156) DDR3 Motherboard @ £84.99 inc VAT
- Support USB 3.0 & SATA 6Gb/s
- APS (Active Phase Switching) offers more than 93% power saving
- Winki 2.0 provides an easy-to-use internet environment
Specifications
- Supports Intel i3/i5/i7 based processors in LGA1156 package
- 4x DIMM of Dual Channel DDR3 1066/1333/1600*/1800*/2000*/2133* (OC) DRAM, 16GB Max
- 6x SATA-II (3Gb/s) Supporting RAID 0/1/5/10
- 2x SATA-III (6Gb/s) Supporting RAID 0/1
- 2x eSATA Supporting RAID 0/1/JBOD
- 1x Ultra DMA 66/100/133 IDE Ports
- 2x PCI-Express x16 Slots Supporting ATI Crossfire Technology
- 2x PCI-Express x1 Slots
- 3x PCI Slots
- 2x USB 3.0 Ports
- 12x USB 2.0 Ports (8x External)
- 2x IEEE1394 Firewire
- Flexible 8-channel audio with jack sensing
- Gigabit LAN
Was £89.99 Inc. VAT
Only £84.99 inc VAT.
ORDER NOW
Xigmatek Asgard Midi Tower Case - Black @ £26.99 inc VAT
The Asgard case is the first entry-level chassis with a black coated interior. Furthermore it is supplied with 1 x 120mm pre-installed black fan, and 3 more fans can be mounted in different area for best possible airflow. The 4 x 5.25" bays will be able to house all your optical drives and you can fit up to 5 x 3.5" bays for all the storage devices you need.
- Screw-less tooling for the bay device
- Dust filter behind front panel for intake airflow
- Dimensions: 185 x 475 x 408 mm (W x D x H)
- 4 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- Front Cooling: 1 x 120mm black fan
- Rear Cooling: 1 x 80/90/120mm fan (optional)
- Side Cooling: 2 x 80/90/120mm fans (optional)
- Front I/O Ports: 2x USB2.0, 1 x HD Audio
Was £28.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) @ £71.99 inc VAT
Enthusiasts looking for the optimal in price performance PSU technology will find the Corsair TX650W/TX750W series of PSUs will meet even the most demanding of required specifications. The Corsair TX650W/TX750W power supplies are engineered using advanced technology and components typically found with high performance power supplies. With design features such as a dedicated, single +12V rail offer the maximum compatibility with the latest system components. Energy efficient circuitry capable of delivering greater than 80% efficiency ratings across 20%, 50%, and 100% load conditions make the TX family of PSUs ideal for the value/quality conscious enthusiast. With a large 120mm diameter temperature-controlled fan that is ultra quiet, yet still more than sufficient to cool the internals of the system, reliability and stability are no longer worries for the gamer, overclocker or enthusiast and high-end system builder.
- Supports ATX12V v2.2 standard and older ATX12V 2.01 spec
- Ultra-quiet 120mm double ball-bearing fan delivers excellent airflow
- 80%+ energy efficiency at 20%, 50% and 100% load condition for less heat generation and lower energy bill
- 99% Active Power Factor Correction provides clean and reliable power to your system
- Universal AC input 90~264V automatically scans and detects the correct voltage
- Dedicated single +12V rail offers maximum compatibility with latest components
- Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit - Protection provide maximum safety to your critical system components.
- High quality Japanese capacitors provide uncompromised performance and reliability.
- Extra long cables support full tower size chassis.
- TX650W Dimension: 5.9"(W) x 3.4"(H) X 5.5"(L);
- MTBF: 100,000 Hours
- 5 Year Warranty
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
BeQuiet Dark Power Pro P8 1200W Modular Power Supply @ £189.99 inc VAT
Those who have big goals in sight and who put intense demands on themselves and their equipment during professional graphics work or extreme gaming situations will redefine their limits, starting now: with Dark Power ProP8, the superlatively powerful and efficient computer heart from be quiet!. The new generation of Dark Power ProP8 is at home in the high watt range, helping anyone who wants more to make a decisive step forward. Starting immediately, the Dark Power Pro P8 universe now contains four models (750W, 900W, 1000W and 1200W) demonstrating (with) up to 92% efficiency (at 230V), earning them 80 PLUS®Silver certification. With Dark Power ProP8 you'll experience top performance up close and personal: Powerful, reliable, efficient and above all: quiet.
We've equipped Dark Power ProP8 perfectly for your tasks: multi-GPU ready with up to six PCIe connectors and up to six 12V rails for stable power. The innovative Overclocking Key opens up new dimensions through the manually operated combination of all 12V rails into one single 12V rail. The especially user-friendly cable management system provides you with up to 37 different connection options. The flexible cable exit and sleeved cable protect against ruptured cables. The prize-winning 120mm SilentWings fan provides the quiet operation for which the be quiet! line is known. The high-quality metallic coating and harmoniously rounded corners lend the new Dark Power ProP8 a distinctive look as well. Dark Power ProP8: this is how your heart beats.
- Switchable between a single +12V rail and six +12V rails
- Dark Power ProP8 provides DC/DC-Technology for high efficiency and stable performance.
- Dark Power ProP8 features a silent 120mm be quiet! SilentWings fan to provide automatic and reliable control of temperature and speed.
- Dark Power ProP8 employs the Ultra Silent Concept to ensure highly silent operation, which means your entire system will run exceptionally quietly.
- Innovative cable management with flexible cable exit:
- Dark Power ProP8 enables a clear allocation of al cables at the power supply unit as well as an easy installation. The flexible cable exit leads the fixed cable properly through the case and avoids cable breaks.
- Multi-GPU compatible:
- Dark Power ProP8 provides 6 PCIe connectors to facilitate parallel operation of several high-capacity graphics cards.
- Dark Power ProP8 offers a variety of different connection options like S-ATA, HDD, FDD, P4, Molex connector (4-Pin), 2x P8-connectors as well as 4 external fan connectors.
- German Engineering
- Variety of safety mechanisms: OCP (Over current protection),OVP (Overvoltage protection), UVP (Undervoltage protection), SCP (Short circuit fuse), OPP (Over power protection), OTP (Over temperature protection)
- High efficiency: 80Plus Silver Rating
Was £200.98 Inc. VAT
Only £189.99 inc VAT.
ORDER NOW
"Primo Trinity" Intel Pentium Dual Core E6500 2.93GHz DDR2 System @ £239.99 inc VAT
The "Primo Trinity" features the excellent value Intel Pentium Dual Core E6500 2.93GHz processor, combined with a selection of high performance yet excellent value, handpicked components designed to meet your desire for the home office or work system.
Why You Should Buy This System?
- The Dual Core E6500 is perfect for multi-tasking applications in the home or office environment
- Small and silent making it the ideal home office or work system
- Large capacity 500GB hard giving you plenty of room for storage
- Precision built and cabled by Overclockers UK expert technicians
System Specification
- Case: OcUK Hades Micro ATX Case
- Power Supply: OcUK Value 450W Power Supply
- CPU: Intel Pentium Dual-Core E6500 "LGA775 Core 2" 2.93GHz
- Motherboard: MSI G41M-P25 Intel G41 (Socket 775) DDR2 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 Dual Channel
- Hard Drive: Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
- Graphics Card: Onboard Intel GMA X4500 Graphics
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: 22x DVD+RW SATA Dual Layer Rewriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
If you're looking for a reliable and affordable system for work or at home this system is perfect for you, why not have this system in your living room?
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 begin_of_the_skype_highlighting**************0871 200 5052******end_of_the_skype_highlighting and they will be happy to help.
The lead time on all pre-built systems is between 24-48 hours.
Was £269.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
"Primo Ignition" Intel Core i3 530 2.93GHz DDR3 System @ £304.99 inc VAT
The "Primo Ignition" features a Intel Core i3 530 2.93GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
- Intel Core i3 530 2.93GHz (Clarkdale) Processer with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK Hades Case
- Power Supply: OcUK 450W
- CPU: Intel Core i3 530 2.93GHz (Clarkdale)
- Motherboard: Gigabyte GA-H55M-S2 Intel H55 (Socket 1156) DDR3 microATX Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo Ignition" is perfect for the user looking for a highperformance system for a low price.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
Was £334.99 Inc. VAT
Only £304.99 inc VAT.
ORDER NOW
"Titan Predator" Intel Core i3 530 2.93GHz @ 4.20GHz ATI Edition DDR3 System @ £569.23 inc VAT
The "Titan Predator" features a Intel i3 530 2.93GHz processor overclocked and guaranteed to a stable 4.20GHz, combined with a selection of high performance, handpicked components placed into an Antec 300 gaming case with ATI Red fans to give it a unique look and feel. Experience a true DX11 experience with ATI Radeon graphics.
- A guaranteed 4.20GHz performance for the price of 2.93GHz
- Choose from a selection of graphics cards to meet your performance needs
- Case: Antec 300 Case with ATI red case fans.
- Power Supply: Corsair Extreme 600W
- CPU: Intel Core i3 530 2.93GHz Clarkdale overclocked to 4.20GHz
- Motherboard: Gigabyte H55M-UDH2 Intel H55 (Socket 1156) PCI-Express DDR3 Motherboard
- Cooler: Prolimatech Megahalem CPU Cooler w/ Xigmatek Crystal LED 120MM
- Graphics Card: ATI DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Featuring a 4.20GHz overclock and utilising the latest ATI Radeon HD5000 Series of graphics cards, the "Titan Predator" is the ultimate hunter.
Was £592.73 Inc. VAT
Only £569.23 inc VAT.
ORDER NOW
OcUK Swift 450W Silent Power Supply @ £15.98 inc VAT
The OcUK swift power supply is sourced and built from high quality components making these reliable power supplies for anyone who is building a home or office computer. They feature a 120mm fan for low noise operation keep the whole PC quiet. These units offer incredible value for money and are ideal for any PC used in the home or office.
- AC input Voltage: 95-132VAC or 190-264 VAC switchable
- AC input Frequency:50HZ/60HZ
- AC input Current:10A res max. for 115VAC, 5A res max. for 230VAC
- Ripple-noise:5A res max. for 230VAC
- Operation temperature:0oC ~+40oC
- Hold up time :16ms
- Dielectric withstand:Input to frame ground 1800VAC for 1 second
- Power good signal
ower on delay time 100ms to 500ms- Ppower fail
C>=1ms- Overload protection :150%
- Universal 20+4 Pin Main ATX Power Connector X 1
- 4 Pin + 12V Power Connector X 1
- Peripheral Connector (4Pin for HDD, CD ROM…etc) X 4
- Floppy Connector (4 Pin) X 1
- Latest L-Type Serial ATA Power Connector X 1
Was £17.99 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
"Titan Decimator" AMD Phenom II X6 Six Core 1055T 95W Edition 2.80GHz @ 3.80GHz DDR3 System @ £539.49 inc VAT
The "Titan Decimator" features an AMD Phenom II X6 Six Core 1055T 2.80GHz overclocked and guaranteed to a stable 3.80GHz. With six processing cores and dual channel DDR3 memory the "Titan Decimator" provides an excellent basis for a workstation, gaming and home cinema system, with power to spare. With either Intergrated graphics or a choice of the latest DX11 graphics, the "Titan Decimator" is proven performer. Game in style with two ultracool Xigmatek Crystal White LED fans for ulitmate cooling.
Why Should You Buy This System?
- A guaranteed 3.80GHz performance for the price of 2.80GHz
- Six Core processing and Dual Channel DDR3 for fast processing
- Choice of latest DX11 cards
- Case: Antec 300 Gaming case - Black
- CPU: AMD Phenom II X6 Six Core 1055T 95W Edition 2.80GHz overclocked to 3.80GHz
- Motherboard: Gigabyte GA-880GM-UD2H 880G
- Cooler: Corsair H50 CPU Cooler (H70 Option)
- RAM: Corsair XMS3 (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Hard Drive: Seagate Baracuda 7200.12 500GB 16MB Cache
- Graphics Card: Intergrated ATI Radeon HD 4250 with HDMI, DVI and VGA ports or a choice of latest DX11 cards.
- Sound: 7.1 Channel Sound (On-Board)
- Cooling: 2x Xigmatek Crystal White LED Fans
Service Package
Destroy your opposition with the "Titan Decimator", with 6 Cores and immense graphics. Get your own "Titan Decimator" today.
Was £562.99 Inc. VAT
Only £539.49 inc VAT.
ORDER NOW
"Ultima Vanquish" Intel Core i7 950 3.06GHz @ 4.00GHz Quad Core DDR3 Crossfire Option System @ £1,109.40 inc VAT
The "Ultima Vanquish" features a Intel i7 950 3.06GHz processor overclocked and guaranteed to a stable 4.00GHz, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system. The ATI Radeon HD 5870 1024MB GDDR5 provides amazing visuals and smooth framerates.
- A guaranteed 4.00GHz performance for the price of 3.06GHz
- Massive 1TB hard drive that delivers rapid load times
- Crossfire upgrade option available.
- Case: Antec 902 Ultimate Gaming Case - Black
- Power Supply: Corsair TX 750W ATX SLi Compliant Power Supply
- CPU: Intel Core i7 950 3.06GHz Overclocked to 4.00GHz
- Motherboard: Gigabyte EX58A-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
- Cooler: Prolimatech Megahalems Rev B CPU Cooler with 2000RPM Sharkoon Silent Eagle 120mm
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
- Graphics Card: HIS ATI Radeon HD 5870 1024MB GDDR5
Service Package
Do you always want more? Do you want to be at the top of your game? Having the fastest system for a great gaming experience is now just a click away. This system is designed and built for gamers, by gamers.
Was £1,189.99 Inc. VAT
Only £1,109.40 inc VAT.
ORDER NOW
Krypton Intel Core i7 950 3.06GHz @ 4.00GHz USB3 Overclocked Bundle @ £538.84 inc VAT
Designed by experts the "Krypton Intel Core i7 950 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- USB 3.0 compatible offering lightning fast transfer speeds
Bundle Specification
- CPU: Intel Core i7 950 3.06GHz @ 4.00GHz
- Motherboard: Gigabyte GA-X58-USB3 (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: Akasa Nero S CPU Cooler
- Artic Cooling MX-3 Thermal Compound
Service Package
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £559.99 Inc. VAT
Only £538.84 inc VAT.
ORDER NOW
Argon Intel Core i3 2.93GHz @ 4.00GHz Overclocked Bundle @ £239.99 inc VAT
Designed by experts the "Argon Intel Core i3 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.00GHz overclock has the processing power and speed to power through the latest games with ease. The "Argon Intel Core i3 Bundle" offers superb gaming performance at an excellent price.
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- CPU: Intel Core i3 2.93GHz @ 4.00GHz
- Motherboard: Gigabyte GA-H55M-UD2H (Socket 1156) DDR3 Motherboard
- Cooler: Artic Cooling Freezer 7 Pro Rev2 CPU cooler
Service Package
Was £259.99 Inc. VAT
ORDER NOW
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply @ £68.98 inc VAT
nonl2brThe ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 140mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
<br>
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
<br><br>
- 150 x 160 x 86mm (W x L x H) <br>
- ATX12V v2.2 and EPS12V <br>
- up to 86% Efficiency <br>
- Overvoltage/OverPower/Short-Circuit protection <br>
- (.99)Active PFC <br>
- MTBF: 100,000 hours @ 25C <br>
- 1 x 20/24-pin ATX <br>
- 1 x 8-pin CPU <br>
- 1 x 4-pin CPU <br>
- 1 x 6-pin PCI-E <br>
- 1 x 6+2-pin PCI-E <br>
- 4 x Peripheral <br>
- 2 x Floppy <br>
- 6 x SATA <br>
<br>
<CENTER>
<IMG SRC="http://www.overclock3d.net/gfx/icons/awards/valueformoney_lores.png" width="150" height="150"/>
<IMG SRC="http://www.guru3d.com/imageview.php?image=10996" width="150" height="150"/>
<IMG SRC="http://www.pcper.com/images/silver_award.gif" width="150" height="150"/>
<IMG SRC="http://www.technic3d.com/article/pics/awards/award_gold_blacks.png" width="150" height="150"/>
</CENTER>
Was £72.99 Inc. VAT
Only £68.98 inc VAT.
ORDER NOW
XFX Pro 850W Core Edition Power Supply @ £89.98 inc VAT
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which, along with XFX’s new EasyRail™ Technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail™ optimizes it all for you. Available in 650W, 750W and 850W, XFX ProSeriesPSUs with EasyRail™ Technology gives you one continuous rail of power covering the total maximum wattage. EasyRail™ Technology Provides Maximum Power Unique, continuous EasyRail™ technology enables you to maximize available power and makes set-up easy.
- Fixed FDD: 1
- Fixed Peripheral: 7
- Fixed 6+2-pin PCI-E: 2
- Fixed 6-pin PCI-E: 2
- Fixed ATX12V / EPS12V: One 4+4-pin
- Fixed Motherboard Connector: 20+4 Pin
-Fixed SATA: up to 11
Was £92.99 Inc. VAT
Only £89.98 inc VAT.
ORDER NOW
Logitech G700 Wireless Gaming Mouse (910-001759) @ £69.98 inc VAT
The Logitech® Wireless Gaming Mouse G700 keeps you comfortable, in control and deep into your game. Its 13 programmable G-Keys can be used to perform single actions or complex macros with a single click. The natural curves fit your hand for epic levels of comfort, so you can keep at it for as long as you want. And its full-speed wireless connection gives you gaming-grade performance coupled with wireless freedom. It comes with a quick-connect cable that charges your mouse and can transmit data over the cable. When your guild gets together, you'll have all the control you need to do battle, complete quests and level up your character. Logitech® SetPoint™ software required for initial setup and is available at logitech.com/downloads.
- 13 individually sculpted, programmable G-Keys let you perform either single actions or intricate macros with multiple keystrokes, mouse events, user-defined keys and repeating. No matter what your game, you'll get deep into it. You have the control you need to play better. To conquer more. To win.
- With natural curves that fit your hand, you get epic levels of comfort, while smooth-gliding feet let you manoeuvre effortlessly. You'll play comfortably, without distraction, for as long as you want.
- Full-speed wireless (1,000 reports per second) helps eliminate lag so you enjoy gaming-grade responsiveness and wireless freedom. You get a steady, powerful connection with no dropouts.
- A quick-connect cable for recharging and data transfer lets you plug in fast and continue your campaign without pause. You'll never run out of power. And you'll always have a backup for reliable connectivity.
- You get a mouse that's crafted just for gaming. The gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you store up to five profiles*. And the dual-mode scroll wheel can switch from click-to-click for weapon selection to free spinning for hyper-fast scrolling.
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Logitech G500 Gaming Mouse (910-001262) @ £29.99 inc VAT
The Logitech Gaming Mouse G500. Your weapon of choice for precision and control. Gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you save and take your settings for your favourite title with you. Weight tuning gives you up to 27 grams of extra weight for personalised feel and control. Dual-mode scroll wheel with hyper-fast scrolling provides click-to-click scrolling that's perfect for weapon selection. On-the-fly adjustable dpi gives you the right level of precision, from pixel-precise targeting (200 dpi) to lightning-fast manoeuvres (up to 5700 dpi), for whatever game you're playing. And ten programmable buttons put valuable macros in your hand.
- Gaming-grade laser gives you game-changing precision at any hand speed.
- Onboard memory lets you save and take your settings for your favourite title with you. No software required.
- Weight tuning gives you up to 27 grams of extra weight for personalised feel and control.
- Dual-mode scroll wheel with hyper-fast scrolling provides click-to-click scrolling that's perfect for weapon selection when you're gaming. Or switch to frictionless hyper-fast scrolling to fly through long Web pages when the boss is looking
- On-the-fly adjustable dpi up to 5700
- Ten programmable buttons put valuable macros in your hand
Was £32.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Logitech MX518 Gaming-Grade Optical Mouse (910-000616) @ £22.98 inc VAT
The Logitech® MX™518 optical gaming mouse gives gamers a precision advantage. Its 1800 dpi optical engine delivers pinpoint accuracy. A sculpted comfort grip helps reduce strain, and slick polytetrafluoroethylene feet glide smoothly across almost any surface. In-game sensitivity switching lets you easily control cursor speed and responsiveness without ever having to interrupt play.
- 1800 dpi optical engine - Delivers precision targeting and pinpoint accuracy
- Sculpted comfort grip - Helps reduce strain
- Polytetrafluoroethylene feet - Glide smoothly across almost any surface
- In-game sensitivity switching - Lets you easily control cursor speed and responsiveness without ever having to interrupt play
- Eight programmable buttons - Provide added control and efficiency
- 3-year limited warranty
Was £24.99 Inc. VAT
Only £22.98 inc VAT.
ORDER NOW
Eclipse Litetouch Professional Keyboard @ £58.99 inc VAT
Sharing the majority of features of its wireless variant, the Eclipse litetouch Keyboard has been designed specifically for desktop operation. With its metal finish, top cabinet and quiettouch™ low profile backlit scissor keys; the Eclipse litetouch Keyboard proves an eye catching addition to any office or study setting. With the same touch sensitive LCD 3-in-1 touch panel as found on the wireless litetouch Keyboard, you can access media, surf the internet or perform office tasks at a touch of a button.
Located to the right of the physical scissor keys, the unique litetouch LCD 3-in-1 touch panel provides the user with unprecedented control over their digital life. With a single press, the LCD 3-in-1 touch panel switches between media mode, numerical-pad mode and ‘MyEclipse™’ mode, providing you with a host of commands which can be used to provide dedicated controls for a multitude of activities from replicating a simple office calculator to controlling a complex media center configuration. When the LCD 3-in-1 touch panel is set to MyEclipse mode, you can personalize the touch panel to access their favorite websites and applications. at a touch of a button. Displaying 12 pre-defined icons covering topics such as shopping, finance, health and entertainment, you can assign each icon with your favorite websites, applications, games, and much more. You can even allocate up to a maximum of three individual websites along with an application of your choice to each icon, all of which will open at the same time and all at the touch of just one button, ideal should you access multiple websites and applications when shopping or dealing with your online finance. In addition, the MyEclipse mode provides 5 numbered buttons which you can choose to cover any topic not already included in the pre-defined icons. Setting up MyEclipse is as easy as drag and drop.
- litetouch™ LCD touch-sensitive Media Panel.
- Trueview™ backlit keys.
- Low profile quiettouch™ scissor keys
- Softtouch™ palm rest
- Slim profile: A full sized keyboard for a compact space
Was £69.99 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Eclipse Wireless Litetouch Professional Keyboard @ £93.99 inc VAT
At home in both the living room and the office, the highly versatile wireless litetouch keyboard fuses state-of-the-art technology with minimalist design, producing a keyboard which places you at the center of the experience, no matter what the task at hand. Communicating over a wireless 2.4GHz connection, the litetouch keyboard features an integrated 360° trackball with left and right mouse buttons, negating the need for a separate mouse and proving ideal for living room internet surfing. Low profile backlit quiettouch™ scissor keys combine with intelligent power control, reducing eye strain, extending battery life and allowing you to operate in a dimmed environment.
Located to the right of the physical scissor keys, the unique litetouch LCD 3-in-1 touch panel provides you with unprecedented control over your digital life. With a single press, the LCD 3-in-1 touch panel switches between media mode, numerical-pad mode and ‘MyEclipse™’ mode, providing you with a host of commands which can be used to provide dedicated controls for a multitude of activities from replicating a simple office calculator to controlling a complex media center configuration. When the LCD 3-in-1 touch panel is set to MyEclipse mode, you can personalize the touch panel to access their favorite websites and applications. at a touch of a button. Displaying 12 pre-defined icons covering topics such as shopping, finance, health and entertainment, you can assign each icon with your favorite websites, applications, games, and much more. You can even allocate up to a maximum of three individual websites along with an application of your choice to each icon, all of which will open at the same time and all at the touch of just one button, ideal should you access multiple websites and applications when shopping or dealing with your online finance. In addition, the MyEclipse mode provides 5 numbered buttons which you can choose to cover any topic not already included in the pre-defined icons. Setting up MyEclipse is as easy as drag and drop.
- 2.4GHz wireless; Up to 30ft / 10m range
- Intelligent power control, extending battery life
Was £109.99 Inc. VAT
Only £93.99 inc VAT.
ORDER NOW
Microsoft Wireless Optical Desktop 700 v2 (M7A-00027) @ £19.99 inc VAT
Enjoy freedom from desk clutter with an optical mouse and a compact keyboard design in Microsoft's most affordable wireless desktop. Control your favourite activities with Media Keys and easily programmable hot keys.
- Optical Technology
- Longer Battery Life
- Sleep and Log Off Hot Keys
Was £23.49 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Logitech C510 HD 720p 8 Megapixel Webcam (960-000594) @ £34.98 inc VAT
With HD 720p video calling and one-click HD upload to Facebook, now you can share your HD world—anywhere, anytime.
- HD video calling (1280 x 720 pixels) with recommended system
- Video capture: Up to 1280 x 720 pixels
- Logitech More HD technology
- Photos: Up to 8 megapixels (software enhanced)
- Built-in mic with Logitech RightSound™ technology
- Hi-Speed USB 2.0 certified (recommended)
- Universal clip fits laptops, LCD or CRT monitors
- 2-year limited hardware warranty
Basic requirements:
- 1 GHz
- 512 MB RAM or more
- 200 MB hard drive space
- Internet connection
- USB 1.1 port (2.0 recommended)
- Windows® XP (SP2 or higher), Windows Vista® or Windows® 7 (32-bit or 64-bit)
For HD 720p video calling and recording:
- 2.4 GHz Intel® Core™2 Duo
- 2 GB RAM
- USB 2.0 port
- 1 Mbps upload speed or higher
- 1280 x 720 screen resolution
Was £37.99 Inc. VAT
Only £34.98 inc VAT.
ORDER NOW
Samsung SpinPoint F4 320GB SATA-II 16MB Cache - OEM (HD322GJ) @ £29.99 inc VAT
The Spinpoint F4 features 7200rpm speed rotation, advanced areal density technology and a SATA 3.0 Gbps interface. Equipped with Samsung's exclusive dynamic balancing technology, the drive's overall stability and reliability is optimized as a high performing solution. Samsung's proprietary SilentSeek and NoiseGuard technologies are incorporated in the drive to offer ultra quiet operation. With a one-head platform design and fewer mechanical parts, the reliability and acoustic features of the Spinpoint F4 have been improved. The drive delivers 10% increased read/write performance and 7% lower power consumption than the Spinpoint F1. The superior performance and high-reliability Spinpoint F4 is engineered for high-end computing in PCs, Macs, high-end workstations and server applications.
- Capacity: 320GB
- Cache: 16MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £32.99 Inc. VAT
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £77.00 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £79.99 Inc. VAT
Only £77.00 inc VAT.
ORDER NOW
Western Digital Caviar Green 1TB SATA-II 64MB Cache - OEM (WD10EARS) @ £41.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 1TB
- Cache: 64MB
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £46.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Western Digital Caviar Blue 500GB SATA-II 16MB Cache - OEM (WD5000AAKS) @ £30.54 inc VAT
WD Caviar Blue hard drives are available with a multitude of available features to deliver rock solid performance and ultra-cool and quiet operation. Pick the drive that suits your needs with the confidence in knowing that all WD Caviar Blue drives are built to the highest standards of quality and reliability. These drives are the perfect solution for family and business computing.
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £31.49 Inc. VAT
ORDER NOW
Western Digital Caviar Black 640GB SATA 6Gb/s 64MB Cache - OEM (WD6402AAEX) @ £50.51 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
- Capacity: 640GB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Warranty: 5 Years
Was £55.21 Inc. VAT
Only £50.51 inc VAT.
ORDER NOW
Seagate Barracuda 7200.11 1.5TB SATA-II 32MB Cache - OEM (ST31500341AS) @ £54.04 inc VAT
Combining proven components and state-of-the-art technology, the Seagate Barracuda 7200.11 drive - the 11th generation of this award-winning desktop hard drive family - delivers high-performing, eco-friendly digital storage. Designed with industry-leading acoustics and power levels, and award-winning Seagate PMR technology, the Barracuda 7200.11 drive offers the ideal combination of world-class technology and lowest total cost of ownership.
- Capacity: 1.5TB
- Cache: 32MB
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £57.99 Inc. VAT
Only £54.04 inc VAT.
ORDER NOW
Western Digital Scorpio Blue 500GB 5400RPM SATA-II 8MB Cache - OEM (WD5000BPVT) @ £38.76 inc VAT
WD Scorpio Blue 2.5" SATA hard drives from Western Digital deliver lightning-fast and ultra-quiet performance hand-in-hand with low power consumption. In addition, they are designed with ruggedness, reliability, and data-protection features that actively watch over valuable data. These drives feature up to a 3Gb/s SATA interface and 8MB cache. WD Scorpio Blue hard drives are designed for portable digital devices of all kinds, including notebook computers, external storage, and digital media players.
- Capacity: 500GB
- Cache: 8MB
- Seek Time: 12.0ms
- Warranty: 3 Years
Was £42.29 Inc. VAT
Only £38.76 inc VAT.
ORDER NOW
Logitech Z520 2.0 Speaker System (980-000338) @ £56.39 inc VAT
The Logitech Speaker System Z520. Bring your music to life - at your desk and around the house. Its 360-degree sound helps project audio evenly in all directions, so you get a great listening experience throughout the room. Amplified two-way design reproduces your music, videos and games with natural sound. With 26 watts (RMS) of power, your system is loud enough for a party and detailed enough for subtle tones. Plug your iPod into the auxiliary jack without unplugging the speakers. You’ll get a full range of sound in a stylish package that’s easy to set up, even with your notebook computer, with this two-speaker stand-alone system.
- Its 360-degree sound helps project audio evenly in all directions, so you get a great listening experience throughout the room.
- Amplified two-way design realistically reproduces sound for clear, natural acoustics.
- With 26 watts (RMS) of power, it’s loud enough for a party. And detailed enough for subtle tones.
- Auxiliary input lets you quickly plug in your iPod without having to unplug the speakers from your computer.
- Simple two-speaker standalone system offers a full range of sound in a stylish package that’s easy to set up, especially with notebook computers.
Was £59.95 Inc. VAT
Only £56.39 inc VAT.
ORDER NOW
Iiyama ProLite E2208HDD 22" Widescreen LCD Monitor - Black @ £110.44 inc VAT
The ProLite E2208HDD Widescreen LCD features true High Definition, 16:9, 1920 x 1080 pixels as its native resolution. Impressive colour reproduction is achieved with a typical contrast ratio of 1000:1 with the User Option to enhance further with Advanced Contrast Ratio enabled for 10000:1. 'Opticolour' automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity.
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 516.5mm x 386.0mm x 193.0mm
- Weight: 4.2kg
- Warranty: 3 Years On-Site
Was £114.99 Inc. VAT
Only £110.44 inc VAT.
ORDER NOW
LG W2246S-BF 22" Widescreen LCD Monitor - Glossy Black @ £111.61 inc VAT
Gamers and movie buffs will love this widescreen LCD monitor. LG’s FLATRON f-ENGINE picture-enhancing chip offers enhanced image definition, smooth motion, and superb colour reproduction, making it ideal for watching films. And, with a 5ms response time, your video games will look better than ever.
- Resolution: 1920 x 1080
- Contrast Ratio: 1000:1
- Connection: D-Sub
- Viewing Angle: 170/160 degrees
Was £123.36 Inc. VAT
Only £111.61 inc VAT.
ORDER NOW
LG W2286L-PF 22" Widescreen LED Monitor - Glossy Black @ £152.74 inc VAT
W86L Series offers various features that can only be realized by an LED monitor. A mega contrast ratio of 2000000:1 provides rendition of realistic images by reproducing even the subtle contrast differences that cannot be recreated by general LCD technology. The monitor also accentuates your interior with a 20mm ultra slim depth and passionate crystal design. Morever, choosing the W86L Series helps to save the environment since it is mercury-free and has low energy consumption level.
Mercury(HG) free, eco friendly display that reduces about 50% in energy consumption through highly efficient LED backlight units.
The best image quality with the world's most extreme contrast ratio. Since the monitor covers virtually all range of brightness and darkness, it can even display jet-black, which is technically the most difficult color to recreate. Experience the clearest.
Switch resolution modes easily at the touch of a button. Converts resolution to enlarge images and text on screen for better viewing.
Photo Effect function allows convenient color correction of photographs and movies.You can easily edit the tone and color of an image, with features similar to those in Photoshop (Blur, Sepia, Monochrome Effect)
Captivating design with glossy and luxurious black surface, compact & slim head, and unique style stand. W86L Series uses LED backlight units to innovatively reduce monitor depth to 20mm. Enjoy simple and refined beauty with an ultra slim silhouette that
Auto Bright offers optimal monitor brightness at all times. Live Sensor automatically turns the power key light on/off by sensing movement. Cinema Mode creates an optimized environment when reproducing online video clips. Time Control reminds you to take
4:3 in Wide is great for watching games and films produced in 4:3 format without image distortion.
Enjoy clean afterimage free display of dynamic movies and games supported by extremely fast response time of 2/1,000 sec.
Features
- LG Flatron LED Backlit
- Resolution: 1680x1050
- Contrast Ratio: 2000000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Inputs: 1x Analogue, 1x DVI-D and 2x HDMI
Was £159.99 Inc. VAT
Only £152.74 inc VAT.
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £164.49 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- Contrast Ratio: 5000000:1
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Was £170.36 Inc. VAT
Only £164.49 inc VAT.
ORDER NOW
Iiyama ProLite E2410HDSD 24" Widescreen LCD Monitor - Black @ £146.86 inc VAT
The new ProLite E2410HDSD-1 is the new 24” screen size to join the iiyama Eco-monitor range. Energy Star rated and using less than 1W in power management mode it is good for the environment yet still features the high specification you come to expect from iiyama. Combining an exceptionally fast 2ms response time, true 16:9 HD and 1920x1080 (2.1mega pixel) native resolution makes for improved colour range and depth in gaming and video and graphic applications. The E2410HDSD features 2 x 2W speakers and analogue and digital connectivity for flexibility across different platforms.
Features:-
- Contrast Ratio: 20000:1
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 4.5kg
Was £152.74 Inc. VAT
Only £146.86 inc VAT.
ORDER NOW
Samsung P2450H 24" Widescreen LCD Monitor - Glossy Black @ £169.99 inc VAT
Film fans and gamers will love the Samsung SyncMaster P2450H TFT display! The Samsung P2450H is a 24 widescreen monitor that willplunge you into all your favourite films and 3D games with breathtakingly realisticresults. The P2450H has a fantastic contrastratio for deep blacks and rich colours. Plus, the P2450H has aresponse time of just 2 ms which is great for online games! Plus, the Samsung SyncMaster 2450H has a wide selectionof connections, including an HDMI port for hooking up a HD games console orcamcorder.
- Contrast Ratio: 70000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 578.0mm x 430.0mm x 190.0mm
- Weight: 5.4kg
Was £199.98 Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
MSI GT640 15.4" WLED TFT Intel I7-720QM, 4GB DDR3, 640GB HDD, NVIDIA GTS 250M 1GB GDDR3 Graphics Card, Win7 Home Premium 32-Bit - Black/Red @ £794.99 inc VAT
Key Features
- The latest Intel® Core™ i7 Processor (I7-720QM 1.60GHz (2.80GHz Turbo Mode)
- Genuine W-indows® 7 Home Premium
- Exclusive ECO Engine Power Management System
- Exclusive Cinema Pro Technology
- Housing combines aluminum alloy construction and brushed metal texturing
- High-end nVIDIA GeForce GTS 250M discrete graphics card (with DDR3 1GB VRAM)
- Digital/analog 7.1-channel headphone output qualified by SRS Premium Sound
- HDMI (High-Definition Multimedia Interface) Output
- Built-in 2.0 Mega Pixel Webcam
- 802.11 b/g/draft-n Wireless LAN with Bluetooth
The Latest Intel Core i7 Processor
The GT640 uses the most advanced Intel Core i7 processor, and is the world’s performance leader among gaming laptops, giving users the ultimate experience in speed.<br>
MSI's exclusive ECO Engine power management system
The GT640 takes advantage of the ECO Engine power management system, allowing users to select from five different usage scenarios—text processing, gaming, movie viewing, presentations, and Turbo Battery modes—and instantly obtain optimized settings for screen brightness and sleep, automatic system sleep activation, and processor performance<br>
The GT640 weighs just 2.7 kilograms (including battery), making it easier to carry than other 15.4” gaming notebooks in the market<
Contoured touch-style hotkeys
The GT640 uses all-new touch-sensitive hotkeys, with a housing sheathed in a glossy black finish, and no extraneous ornaments to clutter its sleek looks.
Highlighted W, A, S, D keys made for gaming
Gamers can find the direction keys as quickly as possible when the action gets hot and heavy, giving them an edge when fractions of a second matter.
Enjoy sight and sound like you’re there as it happens
High-end nVIDIA Geforce GTS 250M 3D discrete graphics card (with DDR3 1GB VRAM)
When you’re gaming, the incredibly fluid, exquisitely crisp, ultra-realistic rendering of even the most complex and dynamic 3D scenes will make for an immersive experience at a whole new level!
Digital/analog 7.1-channel S/PDIF output
The SRS Premium Sound™-certified audio performance, and built-in digital/analog 7.1-channel S/PDIF output ensure you get an utterly captivating aural experience.
Specification
- Intel Core I7 720 Quad Core 1.60GHz (8 Threads)
- 1.60GHz Clock Speed (Turbo Boost supported upto 2.80GHz)
- 4GB DDR3 1066MHz Ram (2x2GB)<br>
- 15.4" WSXGA+ 1680x1050 Resolution LED Screen
- NVIDIA GeForce GTS 250M 1GB VRAM Graphics Card
- 640GB Western Digital HDD
- Blu-Ray DVD-Combo Player
- Wirless N & Bluetooth Connectivity
- 6 Cell Battery (Upto 3.5hrs battery life)
- Digital Webcam
Was £799.99 Inc. VAT
Only £794.99 inc VAT.
ORDER NOW
Samsung RF510-SO2 15.6" HD LED Intel Core I5 460M, 4GB DDR3, 640GB HDD, NVIDIA GT330 1GB Graphics, Win7 Home Premium - Black @ £881.24 inc VAT
Seeing is believing – especially with the Samsung RF510 notebook. Hidden beneath its stylishly minimalist design is the very best in digital technology to provide an extremely powerful mobile multimedia centre. The latest Intel® CoreTM i5 Processor* automatically allocates processing power where it’s needed most while Geniune Windows® 7 Home Premium* enables effortless multi-tasking. You can also experience the ultimate in state-of-the-art 3D gaming and high definition (HD) multimedia thanks to the immersive audio of its unique Enhanced Acoustic Chamber system and blistering performance of a 3D graphics card* with extensive built-in memory.
Combining powerful computing with incredible graphics and long battery life makes the RF510 the perfect road companion giving you anywhere, anytime mobile computing. Features the state-of-the-art Intel® CoreTM i5 Processor*, which accelerates performance by dynamically allocating processing power where it’s needed most using intelligent Turbo Boost technology. A powerful NVIDIA GeForce GT 330M graphics* with 1GB of dedicated graphics memory provides advanced 3D image processing for an exceptional video and gaming experience.
The LED backlit display produces the sharpest images and boldest colors.Its 16:9 aspect ratio also ensures the most accurate, full screen representation of HD movies and games, without annoying black bands. SRS Premium SoundTM delivers more natural and realistic 3D sound for music, movies and games with its bigger acoustic chambers. The RF510 provides enhanced bass, crystal clear dialog and better definition control for maximum clarity at high frequency. Easy Content Share software, based on AllShareTM technology, makes it easy to play multimedia content, including video, photos and music, in multiple Samsung devices.
A Sleep-and-Charge USB port can charge portable devices, such as smartphones or MP3 players, even when it’s sleeping or turned off. Don’t waste time waiting to power up. “Fast Start” lets you get started within three seconds of opening the display or pressing the power button. In this advanced sleep mode, data is also saved on HDD as well as memory, so your content is ready, just as you left it, even if power is suddenly lost or you change the battery. Quickly and securely copy files, images, music or share information wirelessly with any other notebook, netbook or wireless-enabled Samsung PC via an ad-Hoc Wi-Fi connection. If you buy a new PC it also makes it very easy to transfer all of your files. USB 3.0 ports lets you share pictures, movies and data with virtually any modern device at speeds that are much faster than USB 2.0. Advanced communications technologies, including 802.11b/g/n wireless and Bluetooth 3.0 High Speed, provide high speed access to the Internet and your data anytime and anywhere.
Samsung Recovery Solution automatically and regularly backs up your data to the hard drive (or users can also back up to an external hard drive), so it can easily be restored, giving you the peace of mind that you’re always protected. Samsung’s award-winning warranty service*** provides a fast track collection repair and return service in order to minimize disruption and get you going again as quickly as possible.
Features:-
- Operating System: Genuine Windows® 7 Home Premium (64 Bit)
- Processor: Intel® CoreTM i5 Processor 460M (2.53 GHz, 3 MB)
- Main Chipset: Intel HM55
- Memory: System Memory 4GB (DDR3 / 2GB x 2)
- Memory Slot: 2 x SODIMM
- Display: LCD 15.6” LED HD (1366 x 768) 16:9 Gloss
- Graphics: Graphics Processorn NVIDIA GeForce GT 330M (Ext. Graphic)
- Graphic Memory: 1GB gDDR3 (Ext. Graphic)
- Multimedia: Sound HD (High Definition) Audio
- Sound Effect: SRS Premium Sound Effect
- Speaker: 3 W Stereo Speaker (1.5 W x 2)
- Integrated Camera: Web Camera
- Storage: HDD 640 GB (5400 rpm S-ATA)
- ODD: DVD Super Multi Dual Layer (S-ATA)
- Wired Ethernet LAN
- Gigabit LAN
- Wireless LAN
- 802.11bg/n
- Bluetooth: Bluetooth V3.0 High Speed
- Others: I/O Ports: VGA, HDMI, Headphone-out, Mic-in, Internal Mic, 2 x USB 2.0, 2 x USB 3.0 (Chargable USB included)
- Multi Card Slot (4-in-1 (SD, SDHC, SDXC, MMC)), RJ45 (LAN), DC-In (Power Port)
- Security: Norton Internet Security (60day free), BIOS Boot Up Password, Kensington Lock Port, - Samsung Recovery Solution
- AC Adapter: 90 Watt*
- Battery: 6 Cell (4400mAh)
- Dimension (WxDxH): 379.6 x 255.5 x 31.4 ~ 37 mm (14.9” x 10.0” x 1.23” ~ 1.45”)
- Weight: 2.6 Kg (5.73 lbs)
- Rose Red
- Warranty: 2yrs
Was £949.99 Inc. VAT
Only £881.24 inc VAT.
ORDER NOW
Samsung R730 17.3" LED Intel Dual Core T4300, 4GB RAM, 320GB HDD, DVD-RW, Win7 Home Premium - Open Box @ £394.99 inc VAT
If you want a laptop that will deliver top-drawer performance without the top-drawer price tag, then take a look at the Samsung R730. It’s powerful, and it won’t empty your pocket.
If you’re into music and movies, or you want to multitask all your favourite applications without your laptop lagging behind then the R730 is for you. It’s got a powerful Pentium Dual Core processor alongside a huge 4GB RAM, so it’ll make light work of your heaviest tasks; it’s ideal for students and home users who want a machine that covers every base.
Great performance is nothing without great visuals to match and the R730 definitely doesn’t disappoint. The stunning 17.3” high-definition LED screen turns this laptop into your own portable cinema. Wherever you go, you can enjoy your favourite films in unprecedented detail; sit back, relax, and enjoy.
When the movie’s done and you fancy some music, the R730 will continue to impress. The SRS 3D Sound technology will give your songs a whole extra edge, and the massive 320GB hard drive will ensure you’re never struggling with space to store them.
Samsung understand that in today’s modern digital world, the connectivity of your laptop is key. The R730 comes with a HDMI port, so you can hook it straight up to your big screen TV and use that as your monitor. It’s got wireless technology and an integrated webcam too, so you’ll never be more than a few clicks away from your online social life.
Inject your life with some Samsung style, and enjoy amazing power at an affordable price, with the Samsung R730 laptop.
Features:-
- Intel Pentium Dual Core T4300 2.1GHz (Dual Core)
- 4GB DDR3 SDRAM - 1066 MHz
- 17.3" Superbright LCD
- 320GB HDD
- 17.3' TFT 1600 x 900
- DVD±RW (+R double layer) / DVD-RAM Optical Drive
- Intel GMA X4500 Dynamic Video Memory Technology 5.0 Graphics
- Integrated Webcam
- Microsoft Windows 7 Home Premium
- 6 Cell Battery (upto 4hrs battery life)
- 2.84kg weight
- HDMI Port
-12 Month Warranty - Open Box
Was £399.49 Inc. VAT
Only £394.99 inc VAT.
ORDER NOW
Sony VAIO FW56E 16.4" True HD LED TFT Core 2 Duo T6670, 4GB RAM, 500GB HDD, Blu-Ray, ATI HD4570 512MB Graphics, Win7 Home Premium - Charcoal Gunmetal - Open Box @ £563.99 inc VAT
For a laptop that’s got both style and substance? Well that’s exactly what you get with the Sony VAIO FW56. It’s one of the first laptops to come with the new Windows 7 operating system, putting you at the forefront of computing innovation.
Whether you want to play some music, watch a movie, get online with a game or just keep in touch with friends, the FW56 will suit you. It’s got a powerful Core 2 Duo processor and a huge 4GB RAM making it ideal for multitasking all your main applications. Don’t worry about doing too many things at once; the FW56 will have no trouble keeping up.
When you buy a Sony you know you’re going to get style. The FW56 looks great whether it’s switched on or turned off, coming in a striking chassis with a crystal clear 16.4” x-black LCD display and a ATI Radeon HD 4570 graphics card. It’s been designed with the film fanatic in mind too; when you combine those features with the fancy Blu-ray drive you can recreate the cinematic experience in the comfort of your own room.
If you’re one of those people who love to collect thousands of songs and hours of video you’ll need enough space to store them all when you’re not being entertained. The FW56 comes with a massive 500GB hard drive, so you won’t have to worry about finding room for your latest files; there’s enough room for everything you could possibly want.
It doesn’t just have to be your new laptop looking good; you can too when you chat to your friends on the integrated webcam using the wireless internet. Bluetooth technology means you can upload the latest photos from your phone in a flash too.
If you want a seriously stylish laptop that’ll keep you effortlessly entertained then look no further than the Sony VAIO FW56.
Features:-
- Intel® Core 2 Duo Processor T6600 2.20GHz
- 1066MHz FSB
- L2 Cache 2MB
- Mobile Intel® PM45 Express Chipset
- 4GB DDR2 800MHz
- Configuration: 1 x 4GB
- 500GB SATA 5400 rpm
- Blu-ray Disc™ Combo Drive (reader): BD ROM/ DVD+-RW/+-R DL/RAM Drive
- Operating System: Genuine Windows® 7 Home Premium (64-bit)
- Windows Media Player 11
- VAIO Recovery Utility - HDD recovery (hidden partition)
- 16.4” X-black LCD with multiple lamp
- 16:9 Aspect Ratio
- Resolution 1920 x 1080
- Resolution Type: Full HD (1920x1080)
- ATI Mobility Radeon™ HD 4570 Graphics
- Total available graphics memory of Approx. 2790MB * with dedicated GDDR3 Video Memory of 512MB
- Intel® High Definition Audio compatible
- Built-in Stereo Speakers
- 3D Surround
- Keyboard and Touchpad
- Integrated Wireless LAN
- Wireless LAN Max. Date Rate (Mbps) 300 (RX)/ 150 (TX)
- Wireless LAN Range (m) max. 100
- Wireless LAN Type 802.11a/b/g/Draft n
- Ethernet network 10BASE-T/100BASE-TX/1000BASE-T
- Integrated Bluetooth (Version) 2.1 + EDR
- Bluetooth Range (m) 10
- Lithium-Ion battery (VGP-BPS13/S)
- Battery Life (min) 200
- Battery Charging Time (min) 220
- Dimensions: Height: 29 - 37mm, Width: 384mm, Depth: 261mm
- Weight: 3.2 kg
- 1 x 4 Pin i.LINK™ (IEEE1394), 400 Mbps
- 1 x DC In
- 1 x Audio Out Stereo Headphones/Speakers Jack
- 1 x Microphone Jack (Stereo)
- 1 x RJ-45 Direct Port (Network)
- 1 x HDMI™ out
- 3 x USB 2.0 Type A
- 1 x VGA Connector for Monitor
- 34mm Express Card Slot
- Memory Stick™Duo, Memory Stick™ PRO HG Duo, high speed data transfer
- SD Card Slot
- Built-in 'Motion Eye' Digital Camera 1.3mp
- 1 Year Manufacturer Warranty (Open Box)
Was £579.99 Inc. VAT
Only £563.99 inc VAT.
ORDER NOW
