I had a similar problem trying to do a repair.
The system HD needs to be the first one seen by the install program. On my system the first HD seen by my BIOS wasn't the same as the what the install program saw as the first HD.
I solved it by removing all my data disks and leaving only the system disk. I then connected it so that it was the first HD seen by the install program to avoid future problems.
My system drive is drive 0 but it still only gives me the option to do a new install.
Which disk should I be using for the re-install? Just wondering what the home computer restore cd is for?
