this is going to be tough, but how about a Corsair H50/70? fit the radiator too the fan hole at the rear and attach the supplied fan to it.
 The computer i purchase was a pre built from overclockers see. Sorry to be difficult
I may want to make note that this will be my first time to install a cpu cooler, so the more user friendly and straight forward would be idealThe computer i purchase was a pre built from overclockers see. Sorry to be difficult
when I say tough, i dont mean the fitting of the cooler, but rather suggesting a cooler that points the right way, without seeing any others apart from my own i cant suggest anything else in case its not right.
also I dont know if some AM3 motherboards have the socket rotated differently.
)the akasa venom has already been suggested (even by yourself)
and in answer o your using an extra viper fan as a case fan, you might as well strap it onto the other side of the cooler (so one on the front pulls air in, one on the back sucks it out)(, and keep the current fan you got in the picture where it is
Titan Fenrir will fit the right way as well, so will the Coolermaster V6.
Come to think of it, in your position I'd go for a downblower like
- http://www.overclockers.co.uk/showproduct.php?prodid=HS-027-SY&groupid=701&catid=57&subcat=1395
The case extractor fan and psu fan will pull enough air up the case and over it to do a good job.
BTW I am 99% certain the Venom will NOT blow out the back when fitted to your board.
Cheers,
vfm
ah, orientation does change things a bit.
the zalman i have can be mounted either way, its just a simple bar that clips onto the existing plastic mould on the motherboard (like the stock cooler does). You can either stick it through the middle of the heatpipes (so cooler faces up/down), or thread it in between them (left/right)
I have a thermolab baram on my 955be in a push pull config. Works a treat!
) so I dunno, maybe this could help you a bit? Last year when I built mine, I ended up removing the stock cooler of my AMD cpu, and replacing with a Thermalright Ultra 120 Extreme and a bunch of 120mm fans. I don't see any reason why you can't have yours facing the back like mine. Of course, it probably means removing the motherboard for access to brackets, and you also need to do some case measurements and cooler measurements (for whatever cooller you want) to make sure you can put the side cover of the case back on.
