***Official Left 4 Dead 2 Thread***
I'm surprised that there isn't a fix available in the form of a sourcemod plugin to be honest.
It might not be well known enough yet. Pretty sure there were fixes last time.
Though the problem is that unless its you setting up the lobby with the intention of going to a server with the fix... chances are always slim so it'll best to just not play it in the first place.
although this time the fixes may make it impossible for the tank to break through.
I never understood the reasoning behind that... theres a window for the tank to break through in the room upstairs. Breaking through that door as tank would allow the survivors a shortcut. Why would you EVER break it down?
hi there, i will be up for a game if any one can join...thats if i get back from work on time.......also i run a couple of 8 player coop fun servers......with:
8 players coop
item points and buy system
l4d2 custom stats
crawl when incapped
no melee fatigue
green tank
more special infected
lethal shots (duck and charge with sniper rifles)
low mavity
refillable m60s on ammo pile
type !heal to heal
type !refill to refill your weapon
drop weapon when hit by tank or special infected
just for fun when folks get bored playing normaly....
also got a lot of custom maps , when valve eventualy fix the game again....
cheers chris
yay no mercy door exploit fixed :D
pdates to Left 4 Dead 2 have been released. The updates will be applied automatically when your Steam client is restarted. The major changes include:
Left 4 Dead 2
New Mutation: Hunting Party
Fixed door exploit in No Mercy
Now Allow thirdperson settings in cooperative game modes
Fixed add-on campaigns not always appearing in the campaign selection screen
Restored dedicated server support for add-on campaigns
Fixed some rendering artifacts on Mac
Added support for Russian audio in The Sacrifice and No Mercy
Game correctly recognizes the audio language set in Steam
Please ignore the 8v8 announcement tonight, came up in error. Must have set it to Friday accidentally. Will fix now.
Also updating servers as we speak. Been busy with work until now. :)
Well that stealth mini update was a massive pain in the arse.
But yeah gg, if it wasn't for the bad luck with the tanks it would've been a lot closer.
just wandering what you folks are getting fps wise on this game? and what kind of system you have.....
reason i ask is ive just built the missus a :
core 2 duo e4700 @ 3.2ghz
4 gig ram
asus gtx460 768mb
only running @ 1360 x 768
and getting a lot of low fps into the 20-30s most of the time,with most settings on high, i can get it to run a bit better running everything on low and no v sync.....
just thought it should have run better than this......
It should run much better than that. I got a good performance increase by turning multicore rendering off in the options. It used to stutter and fereeze badly too
