- 17 Oct 2002
- Retired Don
Apparently the radiator cap wasn't releasing pressure over time. Hasn't ever over heated until last week, was fine over the summer etc!
Question you have to ask yourself now is "why was it warped at the bottom"?
Anyone know, realistically, how much it is for a cooling system change? I'm not talking about if i take it to BMW Parklane, but say a specialist? What is a decent price to pay?
[TW]Fox;17596436 said:Because it is an M54 cooling system. They do that.
Surely a broken rad would leak no matter what?
do you renew the water pump at the same time too and is that a cambelt off job?
[TW]Fox;17596554 said:No, because the E46 doesnt have a cambelt, as cambelts are for shopping trolleys![]()
soarer is not a shopping trolley![]()
[TW]Fox;17596573 said:True, true. More exciting than a 911 infact![]()
lol.
I'd pick a belt over a chain as my preferred drive regardless of engine size if optional, since belts are lighter, do not require lubrication, and provide lesser load on the cam gears to run efficiently. On the flipside, belts have a shorter service life and can cause problems with interference engines. Nevertheless, you can extract more performance from an engine if the cams are belt driven. Chains can bring power loss, valve clatter, rough running and too much flex.
[TW]Fox;17598787 said:You have to replace them often at massive cost often as much as every 40k miles! The fact it has a cambelt means something like a VW Golf has similar if not higher 100,000 mile servicing costs to something like a 5 Series BMW!
40k is a bit low.
A tenner for a belt isn't a massive cost either (unless you can't do it yourself, even then its not rocket science), you will have to do it once or twice... longer if you run a car to its death.
