Gpu's are forever been updated so there is no point in waiting. What resoultion do you game at? If its 1080 or less go with just one 460 or 470. They are more than enough.
It might be a good idea to list the rest of your rig, then people will have a better idea on giving advice. Thats why some folks list there rig in the sig.
That answers that mate. I would go with a nice fat 480!!! or 470sli
Depends on case and mobo. In most scenarios the top card will run MUCH hotter than the bottom due to lack of airflow. The ASUS cooler and most 470's will be very poor in this siuation (I know, I have owned two ASUS 460's in SLI). The ASUS cards are also slightly wider than dual slot, so on many mobos they will touch together.Hi Forum got 400+ quid to get two Nvidia cards,
What’s my best option?
2x Asus 460 1024mb
2 x MSI Cyclone 1024 mb
Or go for 2 x 470?
i have a HAX X case with Asus P6X58D-E Intel X58 and intel i7 950 will a 780 watt psu cope with 2 x 470
its a Hiper 780W PSU - HPU-4M780
Your mobo supports 3x PCIe 2.0 x16 Slots. If you have space to use both the top and bottom slots then you should be fine with any card combo. However, if you can only use the top two (blue) slots, avoid the ASUS and reference 470 cards.i have a HAX X case with Asus P6X58D-E Intel X58 and intel i7 950 will a 780 watt psu cope with 2 x 470
Looking at your mobo, using the bottom slot may obstruct USB and SATA ports. PSU will definately be fine for 2x 460's and should cope with 470's with a little room to spare.
edit: It is probably worth waiting a week for the new ATI cards. NVidia 460/470 prices should should drop pretty quickly when they arrive.
I actually meant to say avoid the ASUS 460's and reference 470's because their cooling is poor when cards are SLI'd right next to eachother. On it's own, the ASUS 460 is a superb card - much better than reference but it's cooler design is not great for close-quarters SLI. The open design of the Cyclone will likely be much better if OP intends to use the two blue PCIE slots.Avoid the ASUS 470? Are they that bad or are you commenting on the space
limitations?
The 470's will be 10-15% faster, but if you intend to overclock, 460's will make most of that up due to better overclock headroom. From a pure price vs performance standpoint, the 460's are better value. 460's also run cooler, use less power and take up less space. However the 470 does have extra memory which may come in handy for some future games.Say I go for the MSI 2 x 460 ?
Is there much diffrence really if I went MSI 2 x 470 Twin Frozr II or is the price not comparible to performance?
Cheers
I will run at 1920 by 1200 as Im getting the Dell 3008 30"
