Jailbroken iPhone Screenshot Thread
Whats your lockscreen theme maxilive?
Is it typeography 4 or something?
Also I like the brown folders? They fit the sonic theme well..
the lock screen is called slanted lock, i saw it last nite as i was browsing :p
;)...search for it on cydia.
the brown folders are part of the Suave HD theme so if you install it then you will have them as standard.
Download suave hd from here and follow the instructions form here, to use your own wallpaper just delete the wallpaper in the suave hd file on your iphone. Be aware the sauve HD folders look different to the default ones I am using, if you want to change them see here for the file you have to modify (it's around 5-6 posts down)
As mentioned its Slanted lock :D
I just followed the instructions and download it off cydia. Great lock screen it even changes colour depending on what time of day it is! I may keep the brown ones, or make my own, still looking to sort out my sonic theme so maybe it scrolls across each page. Not sure if its possible but I'll look into it :D
24k Theme - Install via SSH
Some people seem to have the clear rain lock slider installed but not the full theme, how have you done that?
Who has it installed? I have no idea how to add just a slider but hopefully someone else can help.
I was wondering if you are able to have a wallpaper per a page on the iPhone 4? I've done some googling and can only find the page0.png page1.png methods etc but it doesn't seem to work :p
Then I found another fix for iPhone 4s which involved making a huge icon to cover your wallpaper which sounds a bit of a bodge job to be honest.
Are there any tweaks that allow the phone to automatically free up its memory. I have sbsettings installed but you have to free up the memory manually.
Also is Cydget a thing you'd use these days? Seen some references to it but they are all 2009 references so I am thinking its no longer supported?
