MORPHOLOGICAL AA INFORMATION :
Surface Format Optimizations
Recently a storm-in-a-teacup developed over something called target format substitution. In six titles, AMD developed a profile that intercepted calls to FP16 formats and substituted them for FP11. In practice this made a noticeable performance difference at the time on the titles used, which are all DirectX 9. This substitution is a widely used technique by developers to increase performance without substantially, if at all, reducing image quality. The optimization could be turned off, but only by disabling Catalyst AI - which disables all performance and quality profiles, and alternate frame rendering. The kickback, generated from Nvidia review guides highlighting the substitution and advising that Cat AI be disabled, caused a consensus amongst the community; 'We want enhanced profiles, but we want the option to disable - consumer choice.'
New Catalyst AI, Texture Quality and Surface Format Optimization Controls
AMD listened to this, and now offers a checkbox to disable surface format optimizations. Use this option if you are experiencing quality issues in a game and suspect that this is the problem; not many times will you find it solves the issue. Additionally, AMD combined the Catalyst AI and mipmaps detail level sliders, to make the new texture filtering quality slider. This offers performance, quality and high quality modes, with quality and surface format optimizations enabled by default. This will apply to HD 5000 series as well as HD 6000 series, to be introduced in the AMD Radeon HD 6000 launch driver due now, Catalyst 10.10.
Fundamentally it shows AMD are engaged with the enthusiast community and value their feedback.
INSTALLATION INSTRUCTIONS FOR 5800 SERIES CARDS ONLY
Download this file - http://www.mediafire.com/?m45q04k70m4d28i
Download the hotfix - http://support.amd.com/us/kbarticles/Pages/GPU84AMDCatalyst1010aHotfix.aspx
Extract the hotfix
Extract the MLAA INF.rar file
Then just follow this:
Copy CW106976.inf to \Catalyst_8.782.1RC5_Win7_MLAA_Oct21\Pac kages\Drivers\Display\W7_INF\
Copy C7106976.inf to \Catalyst_8.782.1RC5_Win7_MLAA_Oct21\Packages\Drivers\Display\W76A_INF\
Now start the setup and the function should be unlocked in CCC.
OR
Just download this file modifications already applied and do a complete reinstall
http://www.mediafire.com/?5h6cpooivo4sbox
IMAGES *
Dead space:::::
CC control pannel : Application preference = 0xaa MLAA box Ticked
This new feature is fantastico, can you guess what is useing MLAA and what is not useing MLAA
with MLAA enabled its like your playing the game with 0xaa performance with what looks like 4xaa in use
More images
Final Fantasy with a 2x Zoom on the image
Starcraft II, awsomeness again with MLAA enabled its like your running the game with 0xaa with performance to boot, last mission constant 60fps *example 5970*
Half Life II
Ano 1404.. MLAA
Dragons Age Origins
Hard to see on Crysis but its there and can be seen
Age Of Conan
MLAA : http://i240.photobucket.com/albums/ff144/derFeef/Screenshots/Age of Conan/th_aoc_MLAA.png
NO MLAA : http://i240.photobucket.com/albums/ff144/derFeef/Screenshots/Age of Conan/th_aoc_noMLAA.png
Images are to big so copy/paste to address bar/or click
Crysis Again
Can you tell what is on and what is off ;P
and again
Masseffect II MLAA Zoomed 2x Effectiveness 0% Performance HIT
PERFORMANCE and STATISTICAL information
MLAA vs 8xaa
Important: In PC it runs 11.8x faster than MSAA 8X
Extract the hotfix
OR
IMAGES *
Dead space:::::
More images
Half Life II
Ano 1404.. MLAA
Dragons Age Origins
Age Of Conan
Crysis Again
and again
MLAA vs 8xaa
