I moved back to Nividia the weekend as I had no end of issues with ATI that just made my system unstable. I'm now running a pair of gtx 480's in sli on a rampage 3 with a Corsair 600T case on a single 3008WFP screen and am concerned about idle temps.
Initially I noticed that my top GPU was idling at 71 degrees and bottom one at 51 degrees. This is the temp is settles down to after a day of gaming, internet use etc.. Ambient temps in the room are not much more then 18C. Now I have removed the top HD cage on the 600T when doing the build, so the front fan does provide more cool air to the bottom GPU so it's a given it will run cooler. So I would expect the top GPU to run maybe 7-10 degrees warmer but not 20. Interestingly neither go over 95 running Heaven by the way. Also, I've made sure they are running in single monitor mode with adaptive power settings. Both GPU's clock down properly as expected.
Anyway, I swapped GPU positions this morning. I expected the bottom GPU which runs at 51 idle to now run 10 degrees hotter in the top position. It does. I'm looking at it now and after a couple of runs of Heaven, it's idling at 58. The other GPU which ran at 71 idle in the top position is now in the bottom position. This is now running at 50 degrees. So there is a 8 degree difference between both GPU's.
What I can't understand is how this translates into a 20 degree difference when the GPU's positions are swapped ?
