seasonic are good
go for the 750 watt xfx not 650
i believe it is also 80+ certified
and it will last you for long time
whats your budget
if you can get a seasonic one
then get a seasonic rather an xfx
and look for 80+ gold certified if you can stretch
why say that? not sure if ill ever use the extra 100 wat, as i use ati cards and its another £20 of the cost, 30% extra for just 100w dont seem worth it, unless its a better psu
Only really want to spend around £70 - £80
