Trying to justify Canon 50mm f1.2 L
7 Jul 2010
London
I am considering this to replace my busted f1.8 which was dropped by a friend's child.
I was wondering if anyone's got and whether you are able to comment on the results of the 1.2 lens cf the midrange f1.4 - simply other than build quality, are the results markedly different than from the "lesser" f1.4
Thanks for any thoughts you may have.
If you can afford one, and I assume you can otherwise you wouldn't be asking, it's a fantastic little lens. I've used both the 1.4 and the 1.2 and I'm pretty sure I can see that the L-series lens produces images that have a certain special something about them.
However, it's really not that much different from the 1.4 to justify the extra cost unless you're really working your kit hard. Most people wouldn't be able to tell the difference when faced with two images produced by the two lenses under the same circumstances.
If you're fortunate enough to be in a position where you're making money from your photography and you really need the extra touch of quality in your images that the 1.2 affords, go for it. Otherwise go for the 1.4 and put the spare £900 towards something else you need.
Thanks for the views - money's not a problem, although I don't want to waste it. I just love prime lenses and especially those with gorgeous bokeh.
Still love my minolta md 85mm f2 on my minolta bodies (still a fan of film too).
I would go for the 50mm 1.4 personally, I used the 50mm 1.2L and wasn't impressed with it...
The 85mm 1.2L on the other hand :D
Tiny image I know but its just awesome.
The 50mm 1.2L is unfortunately one of Canon's more 'troubled' L lenses. It's not particularly amazing at anything, can suffer from focus shift, and unfortunately has to live in the shadow of the truly awesome 85mm 1.2L.
If you're using full frame and like prime lenses's it's just got to be the holy trinity. 35mm 1.4L, 85.. 1.2L and 135mm f/2L. I know that lot costs a little more than just the 50 but they're all lenses you just never wan't to take off your camera.
Quite a few folks rate the Sigma 1.4 although have read varying reports about needing calibrated out of tthe box.
I've got the 50 1.4 and love it, really nice bokeh from it. From the comments above, I don't think an extra £800 can be justified.
Was about to post this too - Sigma 50 1.4 seems to be better than the canon 50 1.4
Really? I've been looking into this for a while and it seems while the Sigma is built better and also larger, it seems to be plagued with front/back focussing. Although you're onto a winner if you get a copy that's bang on :)
Just one short.........
Sigma 1.4 here - awesome lens (I've used a good copy).
The Canon 1.2 just seems a bit too hit and miss for a £1100 piece of kit.
Canon 50mm 1.4 here too, VERY happy with the quality of the images and the bokeh :) It's probably my favourite lens that I either own or have tried
here is how i see your situation and many of mine from experience.
If you are struggeling to justify the expense, its not worth it to you. Not saying the lens is not worth it, maybe like me your skill level might not be their to appreciate some lenses. Focusing accuratley at f/1.2 is not easy. Get the 1.4 from either sigma or canon and if you need the extra performance then trade up. I dont mean offence, i recently got the 135 L f/2 and i am still getting used to it and how it handles.
Thanks for the thoughts, I'll order the Canon and Sigma 1.4 lenses and try them both out and decide which one to return once I've had the chance to play with them both to se if I'm happy with the results.
Want to find something that gives me bokeh like my 58mm f/1.2 Rokkor-PG on my X-1 Minolta!
