Ubuntu server install problems.
23 Oct 2006
Aylesbury
Ok, i've got the image downloaded and burnt to a bootable dvd.
It loads up and i have the option to install server, once i click this option i end up on a black screen and it wont go any further.
I've tried the alternative installer (text based) and i get a flashing white cursor at the same point as the black screen before.
any ideas?
I gave up and installed xp in the end.
Only card in the system was a geforce mx440. Both dvd's i tried were burnt and checked, both showed up fine. I also tried one in my laptop to make sure it wasnt the dvd, worked fine.
The motherboard is on the intel 865 chipset tho, so i'm thinking its down to that.
Edit. Correction, its now installing, turned out it was legacy usb support causing the hang.
