OcUK London Photography Meet - Photos
Few more, still going through them all!
For £1.30 and a blob of blutac it was fantastic to use. Set up the tripod, set up the camera, expose the shot, add on about 13 stops, stick the filter on then sit down for 30 seconds or so whilst its working.
Then get greeted with this when post-processing:
is that 13 full stops? ie. F1 gets treated as f90
or 13 stops in 1/3 increments i.e. 1.8 up to f5(ish)
Some pics from me, only had time to do the Borough Market ones so far:-
(01)
(02)
(03)
(04)
(05)
(06)
(07)
(08)
(09) No Judge Comments on this one please as comp entry.
(10)
(11)
(12)
(13)
(14)
(15)
(16)
(17)
(18)
(19)
(20)
(21)
What is it you were using mate, and where can i get one ;) great shot btw
It was a piece of "4 x 3 Replacement Welding Lens - Glass" off an auction site, £1.30 buy price with free postage. Just the right size to stick in front of a 77mm ring or less :)
EDIT would possibly cut the bottom off it to remove the two distracting objects at the left and right hand corners?
They have been annoying me.
Don't want to crop it at the bottom - it cuts off the flow of the bridge.
Don't want to crop it at the sides - you loose the bridge supports.
But a strong vignette works wonders:
You managed to PP it back to (almost) normal colours from that? I'm impressed, I might actually have a go and get some.
edit: I went to London a few weeks ago and did some shots like this; can I add mine or is it just exclusive to this meet?
Sorry Gaffer, once you see it, you cant unsee it i guess :( The vignette has worked well though :)
A great day out and big thanks to MB for organising the permit.
It was great to meet you all and see some faces from the previous meet.... oh, an thanks for not leaving without me :D
I'm liking the shots posted so far, so here goes with a few of mine.
A)
B)
C)
D)
E)
F)
G)
<snip>
how did you achieve those effects?
