2 Nov 2010 at 15:57 #41 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare No need to wait, it will work straight away, but will get better as it cures with heat cycles. you can use either method.
2 Nov 2010 at 15:57 #42 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Double post.
2 Nov 2010 at 16:09 #43 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland well lads im taking a break for about 10 mins hehe
2 Nov 2010 at 17:00 #44 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland well guys im putting the motherboard in the case but having problems with the i/o shield not fitting in the case?
2 Nov 2010 at 17:05 #47 greywolf greywolf Associate Joined 2 Dec 2005 Posts 1,614 Scone said: well guys im putting the motherboard in the case but having problems with the i/o shield not fitting in the case? Click to expand... Make sure its the right way round, and then it just takes a bit of pushing for it to click into place.
2 Nov 2010 at 17:06 #48 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland it wont go in tho i dont want to force it
2 Nov 2010 at 17:07 #49 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland http://i52.tinypic.com/10e4ho2.jpg[/IMG]
2 Nov 2010 at 17:11 #50 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland its no even the right size
2 Nov 2010 at 17:11 #51 greywolf greywolf Associate Joined 2 Dec 2005 Posts 1,614 Scone said: it wont go in tho i dont want to force it Click to expand... This is where I would turn a screw driver round and hit it with the handle.
2 Nov 2010 at 17:13 #52 Musty Pie Musty Pie Soldato Joined 6 Jan 2009 Posts 6,488 Location Hertfordshire greywolf said: This is where I would turn a screw driver round and hit it with the handle. Click to expand... This .... Just give it a whack
2 Nov 2010 at 17:32 #53 RJC RJC Don Joined 29 May 2005 Posts 29,079 Location Kent Give it some welly !! theyncsn be a pain, you need to get it just right
2 Nov 2010 at 17:40 #54 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland done screwing in the mobo now
2 Nov 2010 at 17:41 #55 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland camera out of battery
2 Nov 2010 at 17:42 #56 RJC RJC Don Joined 29 May 2005 Posts 29,079 Location Kent Scone said: camera out of battery Click to expand... Get some!!
2 Nov 2010 at 18:07 #57 Brabbinho Brabbinho Associate Joined 25 Apr 2009 Posts 1,689 Scone said: camera out of battery Click to expand... cant get the staff these days...
2 Nov 2010 at 18:11 #58 ElliorR ElliorR Soldato Joined 20 Feb 2009 Posts 10,357 Location Not where I'd like to be I've met many girls like this over the years.
2 Nov 2010 at 18:28 #59 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland right were on to cables
2 Nov 2010 at 18:28 #60 Scone Scone Associate OP Joined 17 Sep 2010 Posts 473 Location ireland can anyone help me here maybe a diagram or video?
