Man of Honour
- 21 Nov 2004
The fix worked for me
- and I NEVER had puddles on the track even before the patch. So
After the patch i can only play in window mode. any ideas on how to get it full screen?
The fix worked for me- and I NEVER had puddles on the track even before the patch. So
It's awesome isn't it. Now you know what all the fuss was aboutjust need to play in DX9 mode or suffer a mahoosive frame drop.
No visible framedrop (although I am sure there is one)![]()
Yes turning puddles back on has brought the game back to pre-patch poor performance, it seems to me disabling puddles was the "optimizations" referred too in the patch notesI take it back. Quali seemed pretty stuttery to me. Is this a known problem then?
Wasn't the corrupt save bug one of the fixes in the patch ? at least I though it was ...
Sorry buddy but unless you have a backup before this happened then I don't think there is a way to get your data back.
Before the patch it was advised to only quit/exit to paddock after doing qualy as CM thinks quitting early caused the problem. This may apply again by the looks of things.
Edit: It was a fix ...
Now we are talking, a proper fix that doesn't kill performance, and it was down to a random forum member!!
http://community.codemasters.com/forum/6717556-post1.html
face it guys we have all been had over
f12010 = a pile of parp !!
can someone help me?
I dont have any of the lines that guy is talking about in my XML file!
i also dont have that XML file called workerMap2Core.xml
Glad I did not buy this, knew it would turn out like this just like Operation Flashpoint: DR. All hype, fancy graphics and promises of a good game. Codemasters just don't deliver.
