- 18 May 2010
- London
You only need to achive 3.6Ghz and job done.
IF you can go higher whilst mainting control of volts and heat, then do so, but 3.6Ghz is the target.
Edit* I see your cpu is 2.6GHz at stock... so I would estimate your max overclock, if your using air to be about 3.2Ghz-3.4Ghz although you may be lucky and achive more than this.
The process of overclocking is a gradual one, so dont rush it. It takes time. A gradual overclock and a well tested on is a stable overclock. One you can game on and have it not crash on you.
