- 13 Jul 2010
- Brighton
I need to get rid of every file associated with nvidia graphics on a computer to attempt a clean install. Where will I find all the files? It's an XP machine by the way. Thanks.
1) Uninstall drivers through add remove ( nvidia display and physx )
2) Go into hardware manager if there is any nvidia graphics driver under display uninstall that
3) Download CCLEANER , untick any toolbar/browser options on install ! http://www.piriform.com/ and then use the registry cleaner option
4) Download DriverSweeper , untick any toolbar/browser options on install ! http://www.guru3d.com/category/driversweeper/ and tick Nvidia display , Nvidia Physx ( DO NOT CLICK NVIDIA CHIPSET ) , then clean
5) Reboot into safe mode ( F8 ) on boot up
6) CCLEANER ( Run CCLEANER , Registery Cleaner Option )
7) DRIVERSWEEPER ( Tick Nvidia Display , Nvidia Physx ONLY ) , Clean
This will uninstall ALL nvidia display files and physx , sure it's a little long winded but this will 100% clean out any file and it's something i used to do every single time until the 260's came about.
WARNING - DO NOT CLICK NVIDIA CHIPSET , When using driversweeper!. I have to mention this again because there have been some right idiots out there uninstalling the chipset drivers , then threatening the developer of the software when they hose their systems.
Well it's been an hr , something went wrong lol![]()
.You'll have a thumbs up or down in the next ten mins!x
I just installed the latest drivers. Still stuck in 4-bit, with ultra low resolution. Does anyone know how to fix this? I really don't want to have to phone Inno3D in CHINA to get support.
You could try my steps previous but don't reboot into safe mode well just don't reboot , worth a shot. Also the reply to the above post was1. Stuck in 4 bit mode!
2. Head to the Device Manager and find the video card.
3. Remove or uninstall the driver there.
4. Windows will try to plug and play the video card but DO NOT ANSWER THOSE PROMPTS. LEAVE THEM ALONE!! (again!!!)
5. Now with no video driver installed and without rebooting after steps 1 to 5, install the driver you want to test with. When this step is all done, decline the offer to reboot.
thanks, I finally got it. I followed those instructions using the absolute oldest forceware driver I could find, and finally got it to work. phew.
