- 14 Sep 2010
- Port Talbot - Wales
I wouldn't have the CPU fan sucking the warm air off the the back of the GPU...
but at the same time, i dont want the cpu exhausting hot air onto an already warm gfx card, the card runs hotter then the cpu and seeing the difference in temps from having it the other way around, i think it's the best of a bad situation lol
Just an old server case I got from a mate years ago![]()
I think we can conclude that the hsf is just at a wrong angle. I'd recommend you get one that goes from left to right instead of top-down down-top.
otherwise you're just circulating the warm air around in any up/down configuration
pepp77 maybe do a build log (post). Would like to follow your buildI won an Antec P183 Case on another forum and decided to use it to build a file server from parts I had left other from my last upgrade
- I wouldn't worry TOO much about the ones down the bottom, it's already a billion times better in there!!
This thread takes me back....
Last time I looked it was full of CM ATCS' with Barton 3200's and 9800Pro's in them.
Ahhh, the good old days![]()
