Samsung 2TB F4 - 4K sector alignment
18 Jun 2005
I think this is worth it's own thread. This drive uses the advanced 4k sector advanced format but as many have found out even if you format it as 4k in Windows 7 which is a 4k sector aware OS, the OS still reports the drive as 512byte sector (check with HDTune).
Anyway, Seagate has this document which explains it all.(http://seagate.com/docs/pdf/whitepap...4k_sectors.pdf).
At page 6 it explains why the drive are not natively 4k sector aligned but are 4k sector with emulation which is also on the Samsung spec sheet for the F4. What this refers to is the process of translating from the 4K physical sectors used in Advanced Format to the legacy 512-byte sectors expected by host computing systems. For XP and older OS's it's a problem as the drive is not aligned properly after you format it, unless you use a partitioning tool which supports this 4k sector format. Apparently for Windows 7 it's fine as Windows 7 creates partitions with Alignment 0 condition (aligned). There is still the question of slowdown due to emulation though.
What I'd like to know though is if I have to go back and reformat all my F4's since default condition which I selected in disk manager is 512 bytes ?
On the WD Green's the 512 byte emulation is only enabled if you place a jumper over two pins, otherwise it runs in native 4K mode. I'd imagine Samsung drives have a similar function?
I believe there is a jumper on the samsuing too but it does weird things according to reports on storagereview and a few other places.
4k-aware partitioning software?
Correct me if I am wrong, but after reading this article on 4k sectors:
http://seagate.com/docs/pdf/whitepaper/tp613_transition_to_4k_sectors.pdf
I assume that it is possible to align Advanced Format drives (those ones, which are not provided with a special aligning software by HD manufacturer) for Windows XP usage with 3rd party 4k-aware partitioning utility:
"The most critical aspect of a smooth and successful transition to 4K sectors used in Advanced Format is to promote the use of 4K-aware hard drive partitioning tools."
"When using third-party software or utilities to create hard drive partitions, check with your vendor to make sure they are updated and confirmed to be 4K aware."
So to align properly for Win XP usage for example Samsung 2TB F4EG HD204UI one has to find a 3rd party software tool for partitioning, which is 4k-aware, and use that software to partition such disk instead of Windows XP Disk Manager.
Are there any free 4k-aware partitioning tools for Windows XP?
Also would re-aligning utilities provided by WD and Seagate work with other manufacturers HDs like Samsung?
From that article I learnt also that even the newer OSes like Windows 7 do not use 4k sectors directly, they still have to use 512 B sectors. Those newer systems are only capable of aligning Advanced Format hard drives properly during their partitioning, without the need to use 3rd party 4K-aware partitioning software, and that's all:
"there are many aspects of modern computing systems that continue to assume that sectors are always 512 bytes. To transition the entire industry over to the new 4K standard and expect all of these legacy assumptions to suddenly change is simply not realistic. Over time, the implementation of native 4K sectors, where both host and hard drive exchange data in 4K blocks, will take place. Until then, hard drive manufacturers will implement the 4K sector transition in conjunction with a technique called 512-byte sector emulation."
"The sector size increase, described by Advanced Format, occurs at the hard drive media level. Host systems will continue to request and receive data from the hard drive in 512-byte sector sizes. However, the translation from 4096-byte sectors in the hard drive to the 512-byte sectors in the host will be managed in the hard drive. This process is called 512-byte emulation. It’s important that every drive partition start with an LBA offset that is aligned to the drive’s physical 4K sector. If partitions are un-aligned, then hard drive performance will be degraded."
"How can partition misalignment conditions be managed?
The first management step is to avoid misaligned conditions in the first place. This can be achieved by creating hard drive partitions with a 4K aware version of your operating system or through a hard drive imaging software product."
"The second method to managing misaligned partitions is to use partition-alignment software to identify and fix misaligned partitions. This technique should be used during the hard drive integration process."
http://seagate.com/docs/pdf/whitepaper/mb604_4k_transition_faq.pdf
"It’s not practical to make host computer systems talk in 4K native language – at least for a while. There are just too many places the 512 byte assumption is embedded. So, while hard drives will transition to 4K sectors physical sectors on the media, they will still “look and talk” like 512 byte formats to host computers. They will actually emulate 512 byte communications to hosts. This works well as long as the logical 512 byte assumptions from the host computer are aligned with the 4K sectors on the hard drive."
"It turns out that when a hard drive partition is created, the starting position can vary. A 4K drive format is set to work under the assumption that the first 512 byte sector (Logical Block Address = 0) will align perfectly with the first physical 4K sector".
"Alignment 0 ... works well for hard drives & 512 byte emulation because they can neatly map eight 512 byte logical blocks into a single sector. Sometimes hard drive partitions get created so the logical to physical alignment is off...".
"This is called Alignment 1 and it’s not so good for 4K drives when it comes to emulating 512 byte legacy sectors, especially when writing data. Essentially, this alignment can often cause a hard drive to manage a write with extra disc rotations, which slows things down. The results can be sort of dramatic as shown by these test results at HOTHARDWARE.com:
http://hothardware.com/Articles/WDs...Format-Windows-XP-Users-Pay-Attention/?page=2 "
"The Windows XP situation seems fairly well understood in the marketplace. What is much less understood is the situation with cloning and imaging software. System builders, integrators and IT organizations frequently rely on these tools to configure systems for sale or deployment in their organization. Even if you are using Windows Vista or Windows 7, if your hard drive was partitioned with one of these utilities, you’re likely to end up with an un-aligned partition with the potential for poor performance."
http://consumer.media.seagate.com/2010/03/the-digital-den/4k-sector-hard-drive-primer/
Video on 4K sectors:
http://www.techinsight.tv/seagate-on-4k-technology.html
http://usingwindowshomeserver.com/2010/07/27/4k-sectors-and-the-future-of-hard-drives/
Seagate manages aligment problems in the background without any interaction or knowledge of user.
BTW, a warning against 2TB hard drives:
http://www.clearfoundation.com/comp...Itemid,232/catid,24/func,view/id,15489/#15489
Simple question.. do we need to do anything funky with partitioning a Samsung 4k drive then?
Under Windows XP, yes. We should use a tool like Paragon Alignment Tool (PAT):
http://www.paragon-software.com/business/partition-alignment/
to align it properly.
Try testing your speeds before aligning and after to see any difference in writing speeds.
Compare to this test results:
While Windows 7 should align it properly (when partitioning) itself.
BTW, two more articles about that problem:
http://www.anandtech.com/show/2888
http://blogs.msdn.com/b/jimmymay/ar...ignment-make-the-case-with-this-template.aspx
Ah and what about if you partition using tools like Acronis Disk Director, Partition Magic etc?
I actually asked them that question yesterday.
So far only Paragon replied:
"yes, you will still need to use PAT after running Partition Manager. Alignment
to 4K is not done automatically yet."
So they all seem to missed that big 4K change, and have not prepared for it properly, yet. :(
At least such might be the conclusion after reading this thread:
http://forum.acronis.com/forum/11119
Acronis seems to be unaware of their own tool they created for WD. lol ;)
