Don
- 20 Oct 2002
- In a house
wow, you just keep on upping the level
Awesome
Awesome
the force needed to open them is quite high, this needs to be done by the screen twisting 90 degrees open at the end of its travel on the brass rod. However im going to push from near the pivot point, it needs a huge amount of force to lever the doors open which isnt going to work, the cable (doing the pushing) will bend.... use thicker cable? cant it needs to make a 90 bend from the body up, turn then out to the screen. SOOOOO im thinking I need this U shape bit that I will mount the door springs to....... then when its pulled back the doors close AND have tension on them, but pushed forward the doors are free to open. I just need to somehow get the cable to open the doors THEN push the screen out all the way.amazing work, on the mechanism there
But i do have to point out summers been and gone and we got none of the promised topless shots
I worry about you sometimes.![]()
You should see the pictures i have of you ¬_¬
I came.
(amazing work!)
