going to new york in 5 week and im planning on buying a mac book, was at first going to buy an ipad just for using while in bed but thought i would probably want to put wow and football manager on it aswell.
so is the money saved worth it to buy over there?
and
i assume i would only need to get a uk plug to charge it here?
and
do they have built in wifi? speced one up on the us site and it doesnt mention it from what i can see. i upped the memory on it and it came to $1099.
do macbook pros have better gfx?
Having bought a few things in the US, some things to bear in mind:
1) Sales Tax - NY state has a 8.875% sales tax, which is not shown on the internet price (or the instore price, for that matter).
2) Exchange Rate - Currently XE shows £1 is $1.61 - not a bad exchange rate at the moment - work it out with the after tax price to get your final price in pounds if you were going to buy it there.
3) Keyboard - the US MBP will have the US keyboard layout - @ and " are reversed. I don't find it a big problem.
4) Wifi - it comes with Wifi up to G standard.
5) Power - you can either get a plug adaptor for a few quid, or if you want to be really clever, get the plug part of the cable when you return to the UK. The transformer is universal, so that part is fine to use in the UK.
6) Getting it back -to avoid any unnecessary complications with customs, I strongly advise dumping all the packaging for the Mac. I'd also power it up, go online and maybe bring a USB stick with some files and videos to give the illusion of it being brought with you from the UK.
The downside to this is that you won't have a box should you decide to sell it on.
7) Warranty - AFAIK, Apple are pretty good with honouring warranties worldwide. It shouldn't be a problem getting it repaired or serviced over here. Pick up the Applecare warranty extension from Ebay as well.
All in all, if it saves you money, I'd do it. There's virtually no difference between one bought here and in the US and you can get a bit of a bargain if the exchange rate is in your favour.
