- 6 Jul 2009
On my system I'm running Windows 7 64 bit.
Ok, this is what happened:
I was playing NFS Shift (Which I have been doing for a while now with no problems), and my screen went into "Power Saving Mode". I turned the monitor off and back on, and it again went into power saving mode.
I pressed the restart button on my Pc, and nothing happened. I held the power button, again nothing happened. I had to switch it off at the power supply. I tried two times again to make sure it wasn't a one off, and I had the same results. The most I could do was eject the disc.
Any input would be appriciated. I thought it was a graphics issue due to no input, but because my base unit wouldn't turn off I'm thinking otherwise.
