Check out MacAskill's new video, it's the best thing I've seen all year.
http://www.redbull.co.uk/cs/Satellite/en_UK/Event/021242908456696
Cheers... Was only really worried that the tyre was on backwards and was using theQR lever as a point of ref.
Ta![]()
Directional tyres usually have an arrow which tells you which way the tyre should rotate when put on. You can also usually tell by the tread of the tyre. As weescott pointed out, you probably wouldn't be able to tell when on anyway.
I got rid of the speed kings on my pro as soon as it started raininy . There is no warning before they let go completley. Im running mountain kings on mine now which are really good. I would also recomend the panaracer trail tyres i've used them for years.Guys I'm after some tyres recommendations for my Boardman HT Pro.
Currently running the standard Conti Speed King 2.1 on Ritchey WCS rims.
These are perfectly fine running on dry dusty trails, but as soon as it gets a little wet or muddy then the tyres provide no confidence whatsoever. I don't do hardcore riding to be honest, just some xc on canal path type tracks, with some light forest riding chucked in. Want something that won't be too heavy but will give me a good bit of confidence and grip when going for it.
Thanks
What are you upgrading from and will those wheels be any lighter?What do you guys think of these wheelsets??
I would personally spend as much as you can on wheels, even if it means sacrificing other kit.
Something like these are about 1lb lighter than the wheels you linked to and only cost around £70 more : http://www.chainreactioncycles.com/Models.aspx?ModelID=42568
£70 for a 400 gram saving on wheels is a no brainier !!
This frame is fairly popular : Ragley mmmBop
