- 17 Nov 2010
Well thre I was doing some ameture servicing on my sisters PC, it had become slow and bogged down and was filthy inside. So I wiped the drive and reinstalled the software and it improoved 2005. Then I decided to clean inside. I used an airduster to blow all the dust out but where she is a smoker the fans were caked in filt. So I removed these and cleaned them with a toothbrush. I then pur them back and re attached them to the mother board. The only trouble is there are 3 x 3 pin slots and I forgot which fan plugs into which slot. Suffice to say it will not start up at all now. I have tried plugging the 2 fans into the 3 slots in every possible combination, I do it one wan and one fan seems to work, another way and the other works, but never both together and the system will not start up at all! I wonderd if I had damaged the fans in cleaning so I bought new ones and tried again. I can't fathom it out.
Any ideas?
Any ideas?
