Best cheap case
Yes they do. Mostly come with 2 USB on front but sometimes more, you simply connect the leads from the case to the USB header of your motherboard.
Is the Presicion PS05B a good case?
I notice is has Vibration dampening mounts for hard drives
Do these work well?
I have that case and the anti-v hd mounts are not bad. Overall though the case is great. Room for 5x120mm.
But it has no side window or side fan so I'd not recommend it for xfire/sli where you do need a side fan really.
