Hey redshadows
Just been reading through mediaman's thread again trying to make some sense of your "contributions" and work out what it is your actually trying to say inbetween "blowing your own trumpet". . . I offered up some info to the O.P which you felt the need to quote and then take the thread on a slight tangent?
. . . I'm really not sure what point it is your trying to make in relation to this thread or anything I have said but I can see some of your statements are incorrect and "sweeping" or just blatently stating the obvious . . .
I have been overclocking the Q6600 since 2006
Incorrect statement? . . . or you must have a time machine . . . pretty sure the q6600 [B3] wasn't released till early 2007 and the q6600 [GO] wasn't out till middle of 2007
my RAM is running 4-4-4-15 @ 1066 2.0v , 3:4 ,
[email protected] with my NB @ 1.3v
I could tighten nothing in my system, its tweaked
Hmmm that's tweaked but there is scope to "polish your overclock" further and make the system even faster right?
How about 3.6GHz (8x450) with RAM running 4-4-4-15 @ 1080 [6:5] . . . dropping the CPU multi from its native [x9] to [x8] along with the increased FSB would push the NBcc clock from 400MHz to 506MHz which is a 27% increase is System Bus Bandwidth . . . everything would be faster . . . even your "scores"
The type of latency we are talking about here is almost unnoticeable on day to day use.
I can tell the difference in actual usage between a high latency and a low latency system?
Yes, That would bench better, memory speed just makes up part of the story
Your saying a Q6600 running @ 3.7GHz - DDR2-822 [1:1] is "all round" preferable to a Q6600 running at 3.6GHz - DDR2-1200 [3:2] and would bench better . . . thats another sweeping statement as for starters the second config with faster memory would be provide a better user experience due to its lower system latency and be more "snappy" which you wouldn't need a benchmark to tell . . . the first 3.7GHz config running [1:1] would be more "laggy" to use due to its higher latency and would only scores better in tests that were heavily processor based or where the data sat in the processor cache. . . any application that responded to lower tRD and memory bandwidth would pull ahead on the 3.6GHz config even though running at 100MHz less processor frequency
Still GHz is better than any memory dividers/timings.
more GHz is better than ratio for RAM or even timings.
I could run 450FSB with a bad divider or 440 with a good divider and for a fact will score better with more GHz.
Blanket statements, your meaning to say for certain things more GHz is better but for general useage and a snappy low latency system and applications that are bandwidth or tRD effected then paying attention to your Memory/NB/tRD/NBcc is also important and will "score better" and "feel better" than
El-Clunko untweaked [1:1] with higher CPU GHz!
Keep going man . . . I'm hoping to extract a nugget of useful info from you as you been clocking LGA775 since 2007 at least and your clock is pretty decent (if its real and stable?) . . . I was on LGA775 from Nov 2006 to Nov 2009 and never made it past DualCores . . . heres my best day-to-day, air-cooled stable clock using E8400, P5Q-E and some special PC2-5300
El-Tweako
